I got tired of moving around the oxy/acet bottles and torches. I made a cylinder rack and bolted it to the wall and installed a hose reel above it.
Torch Reel
Safety Suggestion
Any chance of those getting knocked over out of there?If so you may want add a chain up higher or also safety caps.I maybe being over cautious, but i,d hate to see a valve shear off a tank.BB402D
TB300D
DIMENSION652
MM250X
MAXSTAR140
HT/PWR-MAX1250 PLASMA
Originally posted by JSFAB View PostWhy are the tanks not sitting on the ground? I'm thinking along the same lines as Admweld, this just doesn't look entirely safe.
I'd put that setup on the floor with a chain around it !
.............. Norm
Same here , did you see the mythbuters knock the valve off of a 80 cf tank?
It went through a block wall and made a hole in the block 3 or 4 feet behind it..
That episode made me think twice about laying a tank in the back of my truck when getting re-fills..
I use small 40s but the way the 80 went off I think a 40 might get in the cab with me..
Gary
my garage is only 19 feet square in side and having the floor space makes perfect sense to me.
i'm trying to make room now to fit my soon to be new utility body in my garage.( i have two inches of room to make it though the door)TB 325
TB 302
dynasty 200sd
spoolmatic 30a/wc24
suitcase x-treme 12vs
miller 211
evolution rage 2
