8"x8"x7' I Beam For Sale Or Trade
  • 8"x8"x7' I Beam For Sale Or Trade
    Let Me Know What You Have To Trade
    Or What You Want To Pay
    Brand New Beam
    RIDGEFIELD PARK NEW JERSEY
    MYBOYDAVE
    Junior Member
    Where are you and the beam located?
    Mike
    MD Welding & Fabricating L.L.C.
    [email protected]
      I take it this is "W" or wide flange beam, do you know what the lbs/ft is? If not can I can get the thickness of the flange and the web?
      Thanks
        I also see you up near NYC do you have a good way to ship to S. Jersey?
          Originally posted by reggie
          7 FT WHATS IT ANY GOOD FOR..GARBAGE,GIVE IT AWAY...
          If you had to buy it you wouldn't consider it garbage. Fwiw I bought a 12' 8" 24 lb. per ft beam and it was $135 . A new 20ft 8" 24 lb per ft was $270.
          Bernard 3500ss water-cooler
          Rockwell vertical mill
          Beverly Shear B-3
          Beverly Shear JR
          Home-made English wheel
          Milwaukee Porta-band
          " Sawz-all
          Tennsmith 36" stomp shear
          Powcon 300st
            Short lengths of I-Beam such as this are great for making heavy duty horses.
            Weld a couple lengths of channel on and use angle iron for the base and you're good to go.
            I have a couple that I use all the time for mounting a vice, a tubing roller, a pipe bender, etc. One is the same height as my welding table, which works great for larger pieces.
            Not useless, but reallly doesn't have much "commercial" value. I get my beams out of my buddy's scrap dumpster (runs a large fab shop).
            Syncrowave 250 DX Tigrunner
            Miller MM 251 w/Q300 & 30A SG
            Hobart HH187
            Dialarc 250 AC/DC
            Hypertherm PM 600 & 1250
            Wilton 7"x12" bandsaw
            More grinders than hands
              I have a piece like that with a vise on one end and a notcher on the other. Also if someone was looking to build a log splitter or a small gantry that would be perfect.
              Miller Syncrowave 180
              Miller 211 w/ spool-gun
              Lincoln AC/DC buzzbox
              Cutmaster 38 plasma
              Oxy/Acet torch
              DeWalt Multi-Cutter
              Fiber Metal Helmets(old school)
              Enough Snap-On to be a dealer.
                Funny you should say that - just started looking last week for some to build a gantry to pull a cab and pickup box off of a frame. Too bad it's half a country away.....
                  Nominal 8" flange width could be 31-67 lbs per ft.
                  W8x31
                  W8x35
                  W8x40
                  W8x48
                  W8x58
                  W8x67
                  Not very specific, is it?
                    I hevent seen a solid price tag yet.
                      Need one W8X48 load bearing steel supporting beam about 18 feet long in Edison, NJ
                      Need on W8X48 load bearing supporting, 18 feet long + bearing to be delivered in Edison, NJ
                        Look up steel suppliers near Edison, NJ. Try Samson Metals or Metals USA.
                        MM250
                        Trailblazer 250g
                        22a feeder
                        Lincoln ac/dc 225
                        MM200 black face
                        Lown 1/8x 36" power roller
                        Arco roto-phase model M
                        Vectrax 7x12 band saw
                        Miller spectrum 875
                        30a spoolgun w/wc-24
                        RCCS-14
