20ga Stainless
  • 20ga Stainless
    So the GF wants me to hang a piece of "art" in the dining room. She loves the look achieved by using a 5" blending disc on stainless steel. The required size is 48" x 32". I know 18ga would hang nice and straight, but the weight kinda concerns me. Would some very light tig welding on the backside (for hanger attachments), cause the 20ga to distort? I can weld 18ga with no distortion, but have zero experience with 20ga material. Opinions?
    If you clamp it nice and tight to a heavy piece of aluminum or copper to the back side, the heat will get sucked away and it will remain flat.
    Won't likely burn through either.
    If you don't do this, even a small spot/tack will deform the material. Super obvious on stainless because of the shine.
    "If you build it, they will come!"
      Guess a damp towel on the backside could take the place of the copper heat sink?
        No, you need a real heat sink on something like this. A cold towel rag or towel will not suck up enough heat. You need a piece of copper or aluminum to draw the heat away. something as thin as 20ga will show any distortion very visibly. Try it on scrap piece first and see the results.
        Synchrowave 180
        Millermatic 210
        Spectrum 375
          Originally posted by ivans View Post
          No, you need a real heat sink on something like this. A cold towel rag or towel will not suck up enough heat. You need a piece of Copper of aluminum to draw the heat away. something as thin as 20ga will show any distortion very visibly. Try it on scrap piece first and see the results.
          Tank's for the tip, next time a weld tin stainless a remember this
          XMT 304 cc/cv 208/480 volts
          Lincoln wire feeder LN-25 w/Contactor and Gas Solenoid, w/magnum 400 and 200 gun's (12 ft)
          Spoolmatic 30a w/Flex Head tube 10'' XRA
          Flexible Head Tig Torch w/Gas Valve (25 ft)
          Foot Control RFCS-14HD
          Side-to-side rotary-motion fingertip Current Control
          Miller process Selector Control w/external solenoid valve
          Stainless steel welding cart
          Makita LC1230 Dry cut saw
          www.ricau.ca
