I have a MM251 with the factory installed .035 drive roll kit and liner. I would like to install the .023 drive roll kit for the thinner material that I frequently weld on. Do I need to also change the liner? Thanks
MM251w/M25 Gun
I have run .023 through the .030-.035 liner with no problems with the liner only problem was some bird nesting in the wire if the wire tension was to tight and you had the lead around a cornerTrailblazer 302G
MM 210 with spool gun
Thermal Arc Heffty2 CC/CV suitcase
Smith torches
Porter Cable 14" carbide chop saw
griders and hand tools coming out the WAZOO
I owe! I owe! so off to work I go!
Craneops,
I also have a MM251 and see no problem pushing .023 wire thru the standard 12' M25 gun.
I personally went a little different route. Picked up a new M10 gun off the internet for about $80 and use it for .023 exclusively (very seldom since I use the HH187 for the smaller stuff). The M10 is a much smaller gun and will get into places where the M25 is a little clumbsy.
I kept my M25 but picked up a Bernard Q300 which serves as the main gun (.030 and .035) with 15' lead. The Bernard Q400 is set up for .045 and gets used very infrequently. I have found it much easier to change guns than it is to change liners.
If you get a chance to pick up a Bernard Q Series via the internet, I think you'll really like it vs the M25.
Just my .02Syncrowave 250 DX Tigrunner
Miller MM 251 w/Q300 & 30A SG
Hobart HH187
Dialarc 250 AC/DC
Hypertherm PM 600 & 1250
Wilton 7"x12" bandsaw
More grinders than hands
