Anyone know of any way to adjust the gas post flow on a miller 180 SD? I know there's no external adjustment, but maybe a potentiometer on one of the boards on the inside or something???? I've been going through alot of gas while tacking runs of parts before welding them.
180 SD Post Flow
I belive you'll find your answer here:
page 18 (22 in pdf) section 4-4 post flow control
http://www.millerwelds.com/om/o360j_mil.pdfWill it weld? I loooove electricity!
Miller 251/30A spool
Syncro200
Spectrum 625
O/A
Precix 5x10 CNC Router12"Z
Standard modern lathe
horizontal 7x12 bandsaw
Roland XC540 PRO III
54" laminator
little dog
That model and proceedure appear to be for a newer welder then mine. I'm not exactly sure what year mine is, but the model shown in the manual posted has a digital read out which mine does not. The method of adjusting the post flow utilizes the readout, so I wouldn't be able to do the same on my machine. Thanks for replying though.
What is the serial # on your machine?Will it weld? I loooove electricity!
Syncro200
Spectrum 625
O/A
54" laminator
little dog
