Need Suggestions
  • Need Suggestions
    My friend collects scrap metal. One day I saw a water tank on the back of his truck and of course my eyes lit up. It is about the size of a 30lb propane tank and in perfect condition. I could not let it go to scrap, it is begging to be recycled into something useful. At first I thought a smoker for jerky, then I thought how often I would use it and I wouldn't use it enough.
    Im open for ideas because my mind is a blank right now. If you need a picture, I can post one tomorrow.
    Ken
    What else is there besides welding and riding. Besides that
    Miller Thunderbolt XL 300/200 AC/DC
    Hobart Handler 187
    Dewalt Chop Saw
    4" Air Grinder
    Die Grinder
    Rigid Drill Press
    Kellogg 10hp Air Compressor
    2009 FXDC
    I made a 50 gal hot water tank into a gun safe 25 years ago and i still use it. The only drawback is the galv steel construction was kinda pain in the butt...Bob
      I"m picturing a few different things that can be done with it. The first and most obvious would of course be some kind of cooker or bbq, then my thoughts go to parts washer, beer cooler tub, soak tub for checking tire leaks, scrap bin for small pieces, hopper for sand blaster, some place to keep oildry (speedy dry).
      Man, I could probably keep going but this should be good for a start. Dave
        i came across one not too long ago, and turned it into a smoker/ grill. but that idea has been done several times over. a rod oven comes to mind for me, or weld it in-line with the wood stove in the shop to make a forge...a pic or two of the smoker
        welder_one
        Senior Member
        welder_one
        nothing fancy, just a few hot glue guns for metal
        www.sicfabrications.com
          Is the tank metal or brass?
          Miller 251/30A spool
          Syncro200
          Spectrum 625
          O/A
          Precix 5x10 CNC Router12"Z
          Standard modern lathe
          horizontal 7x12 bandsaw
          Roland XC540 PRO III
          54" laminator
          little dog
            Metal, if it was brass, he would have shot me for taking it
            I like the idea of a rod oven
            Ken
            Hobart Handler 187
            Dewalt Chop Saw
            4" Air Grinder
            Die Grinder
            Rigid Drill Press
            2009 FXDC
              pardon me 4 my question but isnt brass a metal also? just my .02
                lay off the argon:
