Bending Pics Part 3
  • Bending Pics Part 3
    I hope you aren't bored yet..
    Picture 64 requires some explanation: The 180 degree bend on the left was made on the bender around a 3/8 pin. The bend on the right was made in my press brake (also in the Idea Gallery). Notice that the bend is much sharper as opposed to the radius on the left bend. The arc bend was made in the red die. Not shown would be a fixture on the machine to limit the amount of pull of the die, depending on the radius you are trying to aquire.
    Hope this helps those who asked about plans.
    Nick
    Miller 252 Mig
    Miller Cricket XL
    Millermatic 150 Mig
    Miller Syncrowave 200 Tig
    2-O/A outfits
    Jet Lathe and Mill
    Jet 7x12 horz/vert band saw
    DeWalt Multi Cutter metal saw
    Century 50 Amp Plasma Cutter
    Propane Forge
    60" X 60" router/plasma table
    Really neat bender, did you make the dies also? Any ideas about bending thin wall sqare tubing, not very tight radius?
    Where is the Idea Gallery?
    Thanks alot. Tim.
      Thanks alot. Tim.
      Yes, I made the dies. Go to first post at 9:10 am on this bender. The Idea Gallery is to your right in the green box.
      Nick
      Miller 252 Mig
      Miller Cricket XL
      Millermatic 150 Mig
      2-O/A outfits
      Jet Lathe and Mill
      Propane Forge
        hey Monte,
        is your plasma table 5x5ft or 5x60ft?
        Miller 251/30A spool
        Syncro200
        Spectrum 625
        O/A
        Precix 5x10 CNC Router12"Z
        Standard modern lathe
        horizontal 7x12 bandsaw
        Roland XC540 PRO III
        54" laminator
        little dog
          Thanks Monte55,
          I did go read the first post, Those are nice cuts on a band saw.
          I can not believe I didn't see this GIANT green box to my right, thank God it was not a snake, I am used to seeing adds, pop-ups...
          Thanks again,
          Tim.
            Originally posted by SignWave View Post
            hey Monte,
            The table is 60 inch x 60 inch with 49 inches of tool travel. X axis has no limitation for length.
            Nick
            Miller 252 Mig
            Miller Cricket XL
            Millermatic 150 Mig
            2-O/A outfits
            Jet Lathe and Mill
            Propane Forge
              Nice die Monte, good idea...Bob
                These guys are lucky to have you on board, not many can or will take the time to do an informative post such as yours. Great work as always, Dave
                  I had the first request for info on Sept 18. Then five more requests for same so I thought I might get off my duff and do it. I really don't know how to reach someone when they leave just a name. So I decided to put it here and put a comment on the Gallery pic stating so. Metal benders seem to be a common topic on the forum so maybe others will be interested as well. They also need to know there ars 3 posts with pics. Post # 2 seems to be getting lost.
                  Thanks for the kind words
                  Nick
                  Miller 252 Mig
                  Miller Cricket XL
                  Millermatic 150 Mig
                  2-O/A outfits
                  Jet Lathe and Mill
                  Propane Forge
