MillerMatic 251
    Yes the voltage is set to 230
      Hey Ya'll, I just wanted to say thanks for the help!!! I was having a dirty power issue, I was only getting 119 volts on each leg. I called my buddy who is an electrician and he came over and fixed an issue that he found. Now I'm getting 124 volts to each leg and she is burning loud and proud....
      Thanks again, I won't be a stranger.
      Carl
        Message from another member
        There was someone who was logged in as a guest and e-mailed me at Webmaster to post this message here. Hope this helps?
        "Wanted to let mudfreak with the miller 251 problem, that dirt and wire contamination will build up in the wire locaror juas before the wire roolers. the wire will come to a hault and if you hit the trigger again it will start for a little while. need to take a small number drill and clean out the opening. this got rid of the same problem that I had with my 251."
          Only takes a minute to sign up. Super easy, all advice is always welcome,to me at least.
          Tim.
