Mag Drill Turned into a Drill Press.....
  • Mag Drill Turned into a Drill Press.....
    I made a table To turn my Mag drill into a drill press Works on all small pcs.I can drill stainless,Copper,Alum.,Plastic What ever.
    Vernon
    nice job it looks good
      That's smart.
      Jack Olsen
      The Garage(And its slideshow)
      The Car(And its slideshow)
        I've done that with a small segment of beam, in my trailer shop. Vernon, do you have the adapter to use twist bits in yours. I do and it is awesome. I have a Milwaukee and its almost new. My old drill press at the home shop does most of the grunt work.
        Peace,
        Paul
          nice work it so it should work well for your needs.
            Mag drill
            Peace,
            Paul
            Paul,
            No do not have the adapter to use twist bit in mag drill may get one some day.I have a Hougan 2 3/8" by 3" cap. That a a big hole. Well take care
            Vernon
              Big hole indeed, I would recommend the adapter and chuck. Cool plate press for your mag drill!
                Adapter
                Does your adapter use a 3/4" shank With flat spot for set screw
                  Drawlings Of Mag Drill and Base
                  I just found some of my drawlings today of this Mag Drill. Draw this before I built the Mag Drill Base Many Years ago. Vernon
                    Here is a picture of the Hougen adapter.
                    Caution!
                      Adapter
                      Jesus I know what a Hougan Adapter looks like wanted to see his adapter.But thanks for your picture. Vernon
                        I have to remove the entire base from mine and it mouts to the upper drive off the motor.
