I've got a confession to make here. My tig skills would have to dramatically improve just to suck! As far as mig and stick I'm considered the master of the shop and have done it for over 25 years, but little does anybody know I can't tig worth a rats posterior. I have 2 tigs in my shop Maxstar 200 & Dynasty 350) that my guys use on all of our appearance grade work as well as aluminum. I have been fighting tooth and nail like an old fart learning to program his remote not to tig. To keep this short, HELP! My learning resources are limited because my guys can't teach worth a Yaks as!
O.K. what's up with this tig business...
We depend On:
Miller | Esab | Lincoln | Fronius
Baileigh | Drake | Eagle | Knuth
Victor | Harris | Smith | Bessey
Snap-On | Hilti | Ingersoll Rand
Burco/Koco | Onan | BobCat
Tracker | Infratrol | AmeriCast
We belong to or support:
American National Standards Institute
American Welding Society
The Welding Institute
Fabricators & Manufacturing Association Int'l.
Anderson & Co. LLC
Metal Crafters
Tags: None
If youve been MIG'n for 25 years, TIG should be a breeze.
Read Millers Tig handbook. http://www.millerwelds.com/education/TIGhandbook/
And read up on Millers TIG guidelines...
both of these articles can be found here. this is the "front desk" to learning TIG.
I'll bet that once you pick up a torch and see the shiny puddle of quicksilver, you'll get it in 10 hours or less..
Im working on my 6th hour now and I am having pretty good results. I have no shame in what I can do so far, but there is always room for improvement.
get your sefl a pile of coupons... stick stuff together.. get one of the guys to set one of the machines up for you and giver the goose...dont be shy because if you dont try, you;ll never know...
there are other fundamentals to consider but once you get it, youll be thinking how easy it really is.. weld aluminum in ac mode, rule of thumb is about an amp per .001" of thickness- so 1/8th Aluminum would need about 125 amps to weld (go with 85 to start and you wont be so inclined to turn the coupon to a puddle of goopy slop.)
Steel requires DCEN ( direct current, electrode negative) and more or less the same rule of thumb for input current.
try to stay away from DCEP (direct current, electrode positive) until youve got the jist of it all because this setting is most likely to burn out your equipment.
oh yeah, try to keep the tip of the tungstem about 1/8" from the work and without dipping it into the puddle.. You'll know when you do...
Go slow, watch whats happening, absorb the liturature, and practice.. Only 10 hours to a good bead...Will it weld? I loooove electricity!
Miller 251/30A spool
Syncro200
Spectrum 625
O/A
Precix 5x10 CNC Router12"Z
Standard modern lathe
horizontal 7x12 bandsaw
Roland XC540 PRO III
54" laminator
little dog
To me learning to TIG was more like welding with a torch than MIG or stick. If someone had alot of experience with gas welding TIG would be easier for them. Like Signwave said, just step on the pedal. Been TIG welding for about 3 yrs now and still learning. Had lots yrs of stick, then MIG in the shop, but TIG is different to me. Especially to make it look really nice takes tons of practice, thats what I'm still working on...Scott
HMW [Heavy Metal welding]
I try to tell people to get comfortable, nothing harder than welding in a uncomfortable postion (sometimes you have to). I try to rest my palm (the one holding the torch) on the table or on the piece to be welded (untill it gets to hot). I will also at times rest my cup on the base metal (fillets) and that will steady the hand, as every little movement will be noticed in the bead.
Start out just running a few beads without filler, then fuse 2 pieces together, if you have scrap stainless around that to me is the easiest. When fusing try a few different torch movements and also watch the puddle. Once you get the hang of that add a hair more heat and start feeding wire.
I get in a rhythm almost like numbering a sheet of paper top to bottom and touching each number as it is counted, just dont touch the metal with the tungsten.
I have pictures but not shure if it will help, also I dont post very often so I hope this wasnt a waste of bandwidth.
Stu
you will contamintate the tungsten, and most likey the work too. You will mosst likely have to repoint your tungsten so that the arc will go where you direct it to. it may stick too and you'll most likey have to break it off the table or work.Will it weld? I loooove electricity!
Syncro200
Spectrum 625
O/A
54" laminator
little dog
Originally posted by Propulsion View PostI found practicing tig welding on heavy plate first is more forgiving then sheet stock.Will it weld? I loooove electricity!
Syncro200
Spectrum 625
O/A
54" laminator
little dog
Nice looking beads.. very nice
Did you know that I can weld in Cyberspace? Wanna see an example?Will it weld? I loooove electricity!
Syncro200
Spectrum 625
O/A
54" laminator
little dog
SignWave, since you cant make it as a welder maybe you can try your hand as a stand up comic, maybe we will see you on the blue collar tour.
Next time you call somebody out you should take the time and find a little back ground information on them before you call them a lier.
Look up Propulsion on the Motorsports Board and check out some of the parts that I manufacture and the Certifications that I hold and if you think you still have game then bring it.
I have seen some of ^^^^ work and it is some of the nicest Ive seen. I would also agree that thicker material is a bit easier to work with.
Here is a pic of a fused weld on a turndown on an exhaust, its .065 wall 316 tubing. The beads are a bit spaced apart but it wont hurt anything thats what happens when you get in a hurry.
StuAttached Files
Originally posted by Propulsion View PostSignWave, since you cant make it as a welder maybe you can try your hand as a stand up comic, maybe we will see you on the blue collar tour.
If a guy cant make a little joke (and it wasnt even directed at you), whats the point of even trying to make people laugh.
I'll go post my cyberwelds joke somewhere else, Sorry to have upset you. I'll try to keep it on a professional level within your posts from this point on. I trust the remainder of your day will prove to be satisfying to your needs.Will it weld? I loooove electricity!
Syncro200
Spectrum 625
O/A
54" laminator
little dog
Originally posted by Propulsion View PostSignWave, since you cant make it as a welder maybe you can try your hand as a stand up comic, maybe we will see you on the blue collar tour.Will it weld? I loooove electricity!
Syncro200
Spectrum 625
O/A
54" laminator
little dog
Originally posted by Propulsion View PostNext time you call somebody out you should take the time and find a little back ground information on them before you call them a lier.
I dont recall using that word... hmph.Will it weld? I loooove electricity!
Syncro200
Spectrum 625
O/A
54" laminator
little dog
