I recently purchased an LN 25 suitcase I plan on running it off of my Goldstar 452. I would like to run self shielding wire, but I am a little confused on setup should I weld electrode negitive or positive?
Flux Cored set up
straight polarity for flux cored. your 211 wires such as 045 and 062 are good for 1 pass only. great for handrail and small stuff. if you want to use multiple passes and high speed id use lincoln nr232 wire in 072 size at between 25-30 volts. this is a very fast freeze wire and you will smoke a stick welder. i can outweld 5 guys with it. also leaves a strong weld.
