First off thanks Miller for the tape! A customer brought by a project that may require its use ...WOW six broken crossmembers and about ten feet of worn-out floor.
hi mike looks just like the night mare i fell into last year except mine had all but one broke and no floor left under the liner took way to long to do
[email protected] trail blazer 301g with all the fixins:delta band saw dewalt chop saw craftsman drill press, sp-135 mm251 spectrum 375 suite case mig, tig w/hi freq. one welding truck.
This one isn`t going too bad yet , but who knows? The only thing I could do without is the tar under the floor that has to be removed in order to get a satisfactory weld! Asphalt trucks are filthy underneath to say the least.
your right asphalt is bad to work with Ido a lot of dumps that hall asphalt thank god some one invented fire hope it welds up good for you
Thanks Garth. The bright spot to this is that the new floor and crossmembers should weld up pretty well. It`s usually a challange to get origional crossmembers clean enough to weld up .
Mike
Yet another reason my truck will never haul that stinky black goo!
Eight more hours, one more blister, one less grinder!
The first day is such a drastic change it seems like all kinds of progress is being made, but then comes the slow grunt work with the grinder(may it rest in peace).
Wheels , what brand of grinder are you using ? And is that an Ohio plate on that truck ? Dan
Tools to Men are like Shoes to Women you can never have too many .
Miller XMT-304
Miller Spectrum 2050
Miller 10-E Feeder
Hobart 175 Handler
Lincoln AC225
And assorted others
Yes Dan it is from the Buckeye State, we are about 40 miles east of Columbus, and the recently deceased grinder was a Dewalt Dw400.
I knew the 400 was too light duty for what I get into, but I put off getting a replacement. After the fatality I rushed to the local box store and picked up two DW28402`s to fill the void.
lookin real good hope your floor plates get there soon hope to see it when its done thanks
I have found that Metabo's last good , their W7-115 Quick is a good grinder. thats all I use , it has taken everything I have thrown at it . if you get a chance try one . Dan
Miller XMT-304
Miller 10-E Feeder
Hobart 175 Handler
Lincoln AC225
And assorted others
