I think you have to stickweld cast iron. what type of rod to use is beyond me... Im sure some of the other guys here are better suited to answer this one but good luck .
Miller 251/30A spool
Syncro200
Spectrum 625
O/A
Precix 5x10 CNC Router12"Z
Standard modern lathe
horizontal 7x12 bandsaw
Roland XC540 PRO III
54" laminator
little dog
Cast Iron can and is welded using Inconel. The latest copy of the AWS Welding Journal has a "Letters To The Editor" that covers this.
October 2007 issue
page 20
Note that this article does deal with welding dissimilar metals (ie, cast iron to stainless). I suggest that Inconel, being a nickle based metal, is used for roughly the same reasons as Ni-Rod when welding cast iron. The proper Inconel (brand name) electrode or filler wire will need to be identified.
I often tig weld cast iron using a ni-rod filler. This makes a good looking weld and can be used with the cold weld technique or the preheat technique.
Thanks guys, I have the inconel (stick) rods but no nickel rods. My thinking was that since the inconel was nickel based it might work. I have a cultapacker that has cast ends and one is busted. Should I preheat it and let cool slowly after it's welded?
All of the processes can be used for welding cast iron. I have a lot of experience welding cast iron and to the best of my recollection all of the sticks are nickel based. Core-cast 8600 mig wire is excellent, but not cheap (about $400.00 for 12 pounds). Nickel based rods are used for joining dissimilar metals. The nickel is used to help lessen cracking while cooling. It must be absolutely clean, as in grind all the rust, scale, paint, etc. off. Flash it with a torch to get rid of the carbon smear and then preheat it. I usually go to where I am just beginning to see cherry red spots then shut the torch off and weld it. Then post heat it and let it cool on it's own. I just used this technique on some cast iron posts that are between 100 and 125 years old. It worked great. Cast iron is funny stuff and what works one time won't work the next time. Brazing is always a good bet, but I have seen cast it wouldn't stick to, and I have used brazing alloys with 110,000 psi tensile strength. We charged for it by the rod, was very expensive. Personally I don't like NiRod, there are newer and better things out there. Some require no preheat or post heat if properly peened. An air needle scaler works great for this. If you have them it won't hurt to try it. We had inconel in one shop I worked in, but we never used it on cast iron.
Lincoln: Eagle 10,000, Weld-Pak HD, Weld-Pak 155, AC-225, LN-25 wirefeeder Miller: Syncrowave 250DX Tigrunner
Westinghouse: 400+ amp AC
ThermalArc Handy wirefeeder
1 Harris, 3 Victor O/A rigs
Arcair gouger
If you're welding cast iron you can preheat or use the cold weld technique.
Cold welding is making a weld bead approximately one inch long. Stress relieve by lightly tapping the weld surface with a hammer. I don't suggest punching holes in a perfectly good bead with a chipping hammer. Weld another one inch long bead somewhere else on the crack. Lightly tapping this weld to stress relieve. and repeat. Never make more than one weld in an area until previous welds are cold to the touch. This cold welding technique works well on thin section pieces and heavy sections where it may injure something attached to welded part.
Even though the question that was posted asked about using Inconel brand electrodes, there are cast iron welding electrodes made of mild steel, others of approximately a 50%/50% mixture of mild steel and nickel and even others made of approximately 99% nickel. Surely, there are many different types and brands on the market.
