Speedglass
  • Speedglass
    Just wondering if anybody else is having trouble with theres mine keeps cutting out and ive changed everything supplier says its over a year old so i bought a optrell of the competition
    smokin ana grinnin for 20 years
    Owner MARKS MOBILE WELDING
    trailblazer 302
    hobart suitcase mig
    miller 30a al spool gun
    laramy plastic welder
    brocco cutter
    pipe beveler
    all walter hand tools
    I seem to remember some one on the askandy forrum a while back ago haveing a simmular problem. Cant say for sure it was a speedglass though. I think they replaced his filter for him.
    My sincere thanks , Pete.
    Pureox OA
    Westinghouse 300 amp AC stick
    Miller Syncrowave 250
    Hexacon 250 watt solder iron
      they swear tht its the batteries i also have a selstrom ive had it ten years or so might have changed the batts three times thats why i went with the optrell this time no bats
      trailblazer 302
      hobart suitcase mig
      brocco cutter
      pipe beveler
        I have an Optrell and I am very pleased with it. I think you'll be happy with youre decission.
        Pureox OA
          I use my speedglass at work. The biggest problem I've found is The sensor are located in a way that they are easily blocked. If I need to do tight work I throw on old dependable, No electronics. The other problem is, when a forklift passes by the lense will flash with the beacon on the lift.
            speedglas warranty
            The warranty on the hood is for one year and the lens is for three years. At least thats what my dealer did for me.
              re: helmets
              its 2yrs on lens, optrel, jackon, speedglas , miller is 18 months. helmets are like cell phones, if you have had one for 5 yrs, you have got your moneys worth, drop it once or twice, it may be down hill, its lens is crystal, and all self enclosed, no repairs, so be careful with them,
                speedglass
                I've been having trouble with my 9000x batts only last a couple of weeks, 6-8hrs of welding. Anybody know why? Todd
                  re : speedglas
                  the warranty is 2 yrs, take it back, they will replace it , the optrel isnt the better alternative, it has the small lens, and no batteries, then if it isnt used regularly, you must put it in the sun to charge it, also for out of position, or grinding, try the miller elite helmets, or the jackson next gen lens, jackson now has a full view lens, the largest of the brand names, it just came out.... you should get yrs out of a 3M speedglas
                    ohhhh
                    the millers now have 2 yr warranty, thats on headband, also, had alot of ppl ask me
                      love my speed glass helmet. i have not had any problems with mine.
                      trail blazer 302
                      hypertherm plasma
                      millermatic 251
                      high feq. arc starter
                      suit case (extreme 12vs)
                      o/a torches
                      way to many other tools to list
                        We had several speed glass helmets at work they didnt last very long had the same trouble you mentioned with going off. ours would do it right in the middle of a weld. so we switched back to huntsman best we have had so far.
                        sigpichttp://www.sharpsiron.com
                          Thanks, for the info. i bet i don't have 200 hrs on this helmet. Todd
                            Hey Squig or others that are having problems with their speedglass, if you are getting rid of it or throwing away. let me know I will take them all.........Just contact me thru email or PM here.. Thanks Dave.
                              My Speedglas 9000X is either 5 or 6 years old now. Still have the same OEM batteries. I use it 5 or 6 days a week. I manually turn off the helmet vs. letting the 1/2 hr timer turn it off. Never had a lick of trouble. The only quirk I've found to the helmet is that is does go back to shade 3 (non welding) during a weld once in a while, but that is either because I'm in such a tight spot that my hands are shielding the helmets sensors, OR that my outer lens is so darn dirty that the sensors are not getting a clear signal for Arc On-time. Pretty much the same issue both examples. I just move my head so the sensors aren't obstructed anymore, or change the outer lens. No big deal. LOVE THE HELMET. Am thinking of buying a new 9002X and using the one I have now for a back up.
                              Later,
                              Jason
                              Later,
                              Jason
