building a firewood storage rack. questions
  • building a firewood storage rack. questions
    I want to build a firewood rack and need to know what material dimensions would be acceptable. I don't have a fancy CAD program so I made a "sketch" in PhotoShop- go ahead and have a free chuckle. I hope I have given enough information to fetch an answer? I may choose to make a couple 4' wide units instead. This will probably end up being heavy if it's 7' wide?
    I refuse to buy a bolt together POS from Home Depot when I own MM140- even if it's $500 in labor.
    Is 1.5" x 1.5" square A513 tubing overkill or inadequate? What wall thickness will suffice? Am I WAY off base in materials selection?
    I got a rough idea of materials cost by getting an online quote from metalsdepot.com. Metals Supermarket will likely be my supplier and I haven't a clue about what they'll charge for this type of material- they're website is a bit shy of functional?
    A513 Steel Structural Square Tube 1-1/2 X 1-1/2 X 16GA (.065 wall) 48' = $93
    A513 Steel Structural Square Tube 1-1/2 X 1-1/2 X 14 GA (.083 wall) 48' = $118
    A513 Steel Structural Square Tube 1-1/2 X 1-1/2 X 11 GA (.120 wall) 48' = $136
    MillerMatic 140 Auto-Set
    I would look for a metal supplier thats close...Bob
      Metal Supermarkets is 17miles one-way and I am OK with that.
      Thanks.
        Is this going outside? if so you may want to put something under the feet so it doesn't sink.
        Looks good. If outside are you going to cover it?
          It's going outside. I'll probably add material to the legs so it dosen't dig into my concrete patio.
          It will be covered with a lightly customized blue tarp. I sew better than I weld.
          another top notch sketch... with skids added
            Forgot my manners. Thank You!
              Youre going to have a lot of weight 7 feet high with only a 14 inch footprint. To keep from having it fall over on the neighbors poodle, Id make it longer and not as tall. If youre dealing with a confined space bolt it to the garage wall.
              Who do you call when the lawmakers ignore the law?
              Miller AC/DC Thunderbolt 225
              Miller 180 w/Autoset
              Old cutting torch on LPG
                Thank You. a 14" footprint is very skimpy, re-think due. As of this moment it'll be 5'high and 7' wide. I'll increase the feet to 18" perhaps though it will create a trip hazard, at least for me.
                  As a point of reference, Metals Depot's prices are ridiculous.
                  1"x1"x24' 16ga from them is $23. My price for a 20' length in Los Angeles (where things ain't exactly cheap) is only $6.
                  Jack Olsen
                  The Garage(And its slideshow)
                  The Car(And its slideshow)
                    either you won the lottery or have goat pictures of the local m.s. manager
                    seriously -- for any non-trivial amount of material, find a steel service
                    center/dealer/...er. the price difference is major.
                    s to your design -- i built one about the same -- except that it was not
                    as long and i did not put the stretchers along the top. it works well.
                    you _might_ want to consider putting only 1 such stretcher along the top.
                    it would make it easier to load/unload the rack.
                    good luck
                    post pictures.
                    frank
                      For material thickness, you can always look at the POS at Home Depot, and see what they are using. Offhand, I would be inclined to do the bottom in .120" or so, with ".065 a possibility for the sides, and the top which will likely be in tension.
                      Diversion 165
                      Lincoln SP175T
                      Ryobi Drill Press
                      No Name Portable band and chop saws
                      '97 Triumph Trophy 900 (3 cylinder, hence Triple!)
                        Thank Dudes! I'll see what kind of minimums are involved with Service Steel. Probably have to buy a 1000'.
                          At 5' high, 7' wide, filled with 18" long firewood, you'll have 52.5 cu ft of stacked firewood, which is 41% of a cord.
                          Reasonable weight per cord of firewood is 5000lb, so you'll have 2,050lb when filled. Could go up or down depending on length and moisture content, but we'll use that number.
                          If you have 3 legs 18" long at 1.5" wide, you have a bearing area of 81 sq. in. to distribute the 2,050lb load, resulting in a bearing pressure of 25.3psi or 3,644 PSF.
                          3,600 PSF is a large load for below grade footings, considering that residential footings rarely have more than 1,000PSF.
                          But bearing capacity at the surface is MUCH MUCH lower. This is going to sink unless you put it on something capable of supporting 2,000+ lbs, such as a 6" layer of compacted gravel or a 4" concrete slab.
                          If you go with the concrete slab, you can set anchors where the feet will go and use tabs to bolt it down. Takes care of the tipping issue as well.
                            I would just build it all out of 11g- last forever.
                            1 Stringer in the back-top
                            Since it is going on top of the patio just 86 the Feet.
                            Ed Conley
                            MM252
                            MM211
                            Passport Plus w/Spool Gun
                            TA185
                            Miller 125c Plasma 120v
                            O/A set
                            SO 2020 Bender
                            You can call me Bacchus
                              Scratch that. Just read the part about being on a concrete patio.
                              You can bolt it to your patio with wedge anchors on the feet.
