I was at a neighbors the other day and he had a hanger over his welding bottle. He had bought it at a farm show. When I seen it I could hardly waite to get home and make one. His had about six hooks and the one I made only has four. Anyway I thought it was very clever and thought I would pass it on.
Hanger for welding bottle
Saftey first
Make sure you dont overload it could lead to a messy deal!smokin ana grinnin for 20 years
Owner MARKS MOBILE WELDING
trailblazer 302
hobart suitcase mig
miller 30a al spool gun
laramy plastic welder
brocco cutter
pipe beveler
all walter hand tools
thats what i was kinda wondering also if the gas is flamable with the whip and ground kinda closesmokin ana grinnin for 20 years
trailblazer 302
hobart suitcase mig
brocco cutter
pipe beveler
Originally posted by squigthats what i was kinda wondering also if the gas is flamable with the whip and ground kinda close
Tom
Cables are only hung on the hooks after the machine is turned off. The thing was made in a vise and a piece of rail road iron. I welded it together on the floor and on the bench and not on the bottle. Had to hook and unhook the gas to the bottle a couple of times to test the fit. No welding was done on the tank. And again the cables are not hung up until the machine is turned off.
Iliked it so Ibiult one to thanks for the post[email protected] trail blazer 301g with all the fixins:delta band saw dewalt chop saw craftsman drill press, sp-135 mm251 spectrum 375 suite case mig, tig w/hi freq. one welding truck.
Count me paranoid
I've seen the results of a mistake around a pressure vessel, my welding carts (I build) all have ground, AC, and torch holders built in. NOTHING ever touches the tank except when I put on the cap on to take it and have it refilled.
Granted - I only have C25 and Argon tanks, I don't ever want to think "oops" - that flash of a second where you know you screwed up BEFORE you feel the results. If you work with power tools on a regular basis - you would be atune to my thought process. I don't go there.
Steve
