I was at a manufacturing company in '05 that tried something very similiar with a modified Mathey Dearman MagnaCut unit. Worked kind of so-so. Still had to tie up an operator setting up the track etc, and adjust the arm width from the unit to follow the seam. Turned out to be much the same as the Sub-Arc units we were using as far as labour costs. Sub-Arc were faster because they had no tracks to set up, and could travel sideways for cross seams on tank shells.
I welded flange's on pipe's both ends at once with 2 Sub Arcs running on an old metal lathe. It was great until i forgot to put the flux in the hoppers once...Bob
Later,
Jason
thank you for answer
but i mean if you have any program or catalog or any exercise , traning
It appiers to just be an everyday automatic circular track welder. I'd assume that it works just like a Bug-O style track welder. Don't they have a PDF downnload on there website?
Hey,
There is no reason to be rude. People here are trying to help. You are new, like me, this is a great site to learn, if you do like I was told when I was a kid, ask nice and listen to all of the advice.
I know,Iknow I will get beat on for this but there is no reason to be "short".
I hope you get your answer, I have had several of my questions, along with great ideas answered.
This took me longer because I got called about a job I finished, the guy already wants more done, never stops. I hope.
Hope I didn't discourage you.
Tim.
Hey,
Tim.
