Dynasty 200DX on 110
  • Dynasty 200DX on 110
    Has anyone used their Dynasty 200DX on 110?? How does it work for you?
    Did you make a pigtail for it (220 to 110). All feedback would be appreciated
    bert
    I'm not late...
    I'm just on Hawaiian Time
    Hay Bert
    I put a Passport cord on my Dynasty.
    If you go search the Mororsports side for will find a thread started by me about just this.
    I use mine all the time on 110 I take it into deep buildings. saves having to drag leads all the way from the truck. I grab the Dynasty two short leads can of rod a grinder off I go.
    I have done the same thing welding Aluminum hand rail added a cart to the whole mess and brought along a 80 cf argon and welded 3/16" aluminum off 110
    TJ______________________________________
      Fat-Fab,
      thanks, do you remember what your title to the post was??
      bert
      I'm not late...
        you will probably find a lot about it with a search for 110 V or 120V. there have been several posts about the 120V side of it. it puts out a lot more on 120V then one would expect from the looks of the book.
        150amps is no way the max on 120V.
        there is also a lot of info about the pig tails there too. several options as well as plug part #'s. pig tail might also be a good search option.
        good luck.
        thanks for the help
          james, I did a lot of searches using keywords: Dynasty 200DX, 110, 220, pigtail, on both this and motorsports side. No luck. Any other hints? Also tried Fat-Fab posts and still nothing...
          bert
          I'm not late...
            thats strange.
            i'm not real good at searches. but i'll see what i can find for ya and post up any links i find.
            thanks for the help
              Thanks James! I thought I saw one with pictures a couple months ago, but that would have been this forum, but I couldn't find that on either!
              I'm not late...
                found a few from 2004 man i been here for a wile now.
                the passport or DVI cords are good options if you don't intend to use anything but 120/240V power.
                i'll keep looking for better links for ya. its a simple thing to make up a pig tail from standard hardware stuff and a lil bit cheaper then the DVI/Passport option but not a nice looking.
                thanks for the help
                  thanks James
                  I'm not late...
                    Bert
                    I have a dynasty 200dx, wired the main cord for 220 1phase with a 50 amp plug, i dont remember the plug # but will look tomorrow, then made a pig tail with that same plug but the female end and on the male end used a regular 20amp 120v plug, just get a couple of the 50amp female plugs and put whatever you need on the other, these are awsome welders! i have even welded alum with it using my Honda ei2000 inverter generator!! but as soon as i get done with the trailer i started tonight for my new trailblazer302 i will run off that, i hope this helps
                    TB302
                    Dynasty 200dx
                    Hobart beta-mig 250
                    Hobart Handler 140
                      thanks Walley1,
                      my main concern, thinking if I did it that way, was when I wired my 220v 50A plug like you did, I was told not to be concerned as to which wire went where, as they are both used as hot. But now that it is going to be fed into a 110v, I would think it would matter now, now that it IS important to which is hot or neutral going into the 110v plug.
                      Also, what size wire and how long did you use for the pigtail?
                      thanks,bert
                      I'm not late...
                        You could use as small as 12 but I prefer 10 just for improved connections.
                          sberry, 10 sounds good, how long could you run it for?
                          I'm not late...
                            Depends on a couple of factors but with a Dyn you could run a hundred feet without much issue depending on load and incoming service quality.
                              Bert,
                              My 110 to 220 pig tail is rather short, approx 2 feet, i used a 12ga SO cord with 3 conductors, on the 110 end i put the black wire to the gold conector, white/nutral wire to the silver conector and ground to ground, on the other end white to one lug black to one lug and ground to ground... and it works just fine, the machine can see your hot leg, it knows what to do, as for a extension a 10ga "extension" cord would be good... hope this helps
                              TB302
                              Dynasty 200dx
                              Hobart beta-mig 250
                              Hobart Handler 140
