Don't have room in my garage for a 20 ton shear, so I'm looking into smaller (and slower) tools to do the job.
I would like to cut some 10 gauge stainless steel sheet. I've seen a few hand-held shears that can do the job on mild steel.
http://www.amazon.com/Makita-JS3200-...0765898&sr=1-5
Does anyone have experience using one? Does the metal stay relatively flat, or does it curl up the edges like a taco?
In the description of other shears I've seen it mentions a waste curl (about 1/5th inch), which I assume gets all the abuse and leaves the edge of the two remaining halves straight and true. Anyone used one of those?
What's your opinion of shears vs. nibblers? Which one is easier to use to get a reasonably straight line and true edge?
http://www.toolbarn.com/product/bosch/1533A/
Thank you in advance for sharing your experiences.
