Wheels
Thanks guys. I have rigged a spindle so that I can turn the wheel and am going to cut the rim with plasma, add a rolled piece the desired width and re weld the cut off piece of the rim back to the added piece,using a pointer to insure that everything is as straight and true as possible. I'll let you know how it does..
Thanks again for the help.
Wheels
Guest repliedwheels
Originally posted by Herb hardy View PostI am interested to know if any of you guys have ever cut wheels and added a piece in them to make them wider? I'm talking about a stock Ford.Chevy or Chrysler rim. If so, how were you sure that it was true and did you have to try to balance it before the tire was installed?
cutting wheels
I have never done any wheels for a street car but have done some for our race cars. We cut our wheel on a lathe and then cut out the new section on a donor wheel to replace the bead seat on bent up race wheels. We didn't have to worry much about them being perfect as you would on a street car, but yes it can be done. The real question would be is it worth it to try on street wheels? Dave
I have seen it done many times and they did a nice job so i would balance it with the tire...Bob
Wheels
I am interested to know if any of you guys have ever cut wheels and added a piece in them to make them wider? I'm talking about a stock Ford.Chevy or Chrysler rim. If so, how were you sure that it was true and did you have to try to balance it before the tire was installed?Tags: None
