I have a question regarding spot welding , I been triing to make my welds look like tig welds. I been doing this by spot welding continues beeds. takes a little more time , but achieves a tig look. my question is , by welding this way doe's this make my welds weaker, over a continues beed?????
mig welding
In a word, YES, they're weaker. When you stop and start the MIG weld, you also start and stop penetration and MIG is notorious for lack of penetration on starts anyway. However, the use of these welds does not appear to be any more demanding than stitch welding would handle. Doubtful they'll fail, but if they come apart at the corners, you'll see it quickly.Miller XMT-350 CC/CV
Miller S-22A wirefeeder
Bernard 400A "Q" gun
Miller 30-A Spoolmatic w/WC-24
CK 210 & WP-18 GTAW torches
Hypertherm Powermax 30
O/A Rig, Enco 4x6 bandsaw, etc.
Weaker.
Ya have a whole bunch of Cold welds now.
Only time to do that with Mig is on thin sheet metal to help control burn through and Distortion-
looks like a front bumper in yer Pic? 3/16"- 1/4"?Ed Conley
MM252
MM211
Passport Plus w/Spool Gun
TA185
Miller 125c Plasma 120v
O/A set
SO 2020 Bender
You can call me Bacchus
Weaker again.
Notice the little craters. They tend to seed cracks. And if the only reason is to make it look like a TIG weld, well, I hate to burst your bubble but it doesn't exactly look like a TIG weld either.
weaker is what i was thinking. the metal is 3/16, the welder set at 1/4 and gas set at .2 thinking that the extra heat for penatration, sheilding gas staying on after, between welds. I purchase the miller 252 a little over a year , so I'm still learning alot. thanks for you help, I'll stick with the steady beads
It's a weaker weld for sure if you cut it apart you may have voids where you start and stop..2 ea Miller Big 40 Cat cc cv Deluxe
1ea Miller 400P cc cv Deluxe
Miller Big Blue 300 Pro cc cv
XMT 304 cc cv
Miller 350P-XR-A Aluma Pro
Miller 30A
1ea X-Treme 12vs
2ea Miller 12Rc
Miller 24 A
Miller 330 a/bp tig
Dynasty 200 DX coolmate 3
Millermatic 180
Millermatic 180 auto set
Lincoln Invertec 350 Pro
Lincoln Idelarc SP 250
2ea Lincoln LN-25 wire feeders
2ea Powermax 1000
1ea Bortech 300z Borewelder
Little spot welds like those are typically much colder to deposit than a regular weld. That is why it is used on very thin materials. Also as mentioned and eluded to by others there are in fact cracks in each or the craters.
To achieve a "stacked" look with wire feeding in a robotic application and does about the same hand held is to "weave on seam" or whip. Where your arc is traveling ahead of the puddle and then back into it. Much like running 6010 stick. As with any technique there are positives and negatives to whipping. There are other threads out here where we have discussed the differences in penetration, travel speed and ease of application for most techniques so I won't lengthen this out any more than needed. If you'd like further discussion on it just send me a private message and I would be happy to discuss it.
Not to mention the welder cycling so often.Nick
Miller 252 Mig
Miller Cricket XL
Millermatic 150 Mig
Miller Syncrowave 200 Tig
2-O/A outfits
Jet Lathe and Mill
Jet 7x12 horz/vert band saw
DeWalt Multi Cutter metal saw
Century 50 Amp Plasma Cutter
Propane Forge
60" X 60" router/plasma table
