MIG or stick on this one?
  • #46
    Originally posted by HawkerMetalworks View Post
    8 anchor points.
    8 is better than the 4 or 5 that I thought it would be.
    Still, if it was my @ss on the line with this project, seriously, I would definately go back in there and fill those suckers up, both the t-joint and the plate to tank seam, and crank it up too!
    Please, don't think I'm trying to ridicule you. Only trying to help.
    On your shop work, your Millermatic 251 is capable of spray transfer with .035 wire. Pick up a bottle of 98/2 argon/oxygen so you can play with spray. If you have future heavy plate jobs and want to use solid wire and gas, spray it. The welds will go in alot hotter, wetter, deeper penetrating and better fusing, cleaner too. Must be used flat/horizontal only, no out of position. Anything over 1/4" should be sprayed rather than short circuited, with mig solid wire. Play around with it, you'll love it!
    Millermatic175
    MillermaticPassport/Q300
    HTP MIG200
    PowCon 300SM, MK Cobramatic
    DialarcHF, Radiator-1
    Hypertherm PowerMax 380
    Purox oxy/ace
    Jackson EQC
    -F350 CrewCab 4x4
    -LoadNGo utility bed
    -Bobcat 250NT
    -PassportPlus/Q300
    -XMT304/Optima/Spoolmatic15A
    -Suitcase8RC/Q400
    -Suitcase12RC/Q300
    -Smith oxy/propane
    -Jackson EQC
    • #47
      from what i can decipher from the scribbled notes and diagrams on the crane cut sheets that came along with the cut sheets on shackle size, they're using cable lanyards from the shackle to the crane hook.
      if this makes any sense.
      F450 crewcab flatbed
      Miller Bobcat 250
      Miller 8VS suitcase
      Millermatic 251
      Millermatic 180
      Miller Spectrum 375
      Miller Econotig & 150 STH
      Enough snap-on tools to prevent my future kids from going to college
      • #48
        Actual rigging is not on the lift plane.
        Rough drawing of a flying W, you can use shackles in the bite of the 2-chokers, but I would not lay an object down like this, the shackles will destroy the chokers. This type of rigging is great for some lifts. I would use only two chokers to four padeyes, and use snatch blocks in the bite of the two chokers, that way you can lay it down no problem.
        Caution!
        • #49
          Sorry guys I drew that first drawing wrong. It will be clearer just showing one side.
          Caution!
          • #50
            fillet size
            Hey, while we are on the subject, kinda. I thought fillet welds were supose to be 1.25 times the material thickness so two peices of 1/4'' plate would require a 5/16'' fillet. Or is it 1-1/2 times the thickness.
            Just curious. I can't remember.
            '08 F-350
            Vantage 400
            SA-250
            SA-200
            Invertec V350Pro
            Invertec V205T-AC/DC
            Miller 12VS suitcase
            Miller spectrum 2050
            Pipe beveler's
            Track torch
            • #51
              I was taught the true and technical way to measure the fillet size is by the throat depth (root to face distance @ an angle that bisects the joint angle), which should be equal to the thickness of the smaller of the 2 plates in the joint.
              If the face of the fillet is flat or concave, then the legs would have to be a bit longer than plate thickness to reach minimum throat depth. If the face is convex, the legs would have to be at minimum equal to plate thickness. So yes, depending on face shape, the legs could need to be longer than plate thickness to reach mininum throat depth.
              Since most don't have an accurate way to measure throat depth without a fillet gauge, and most put in their fillets with convex face shape, it's simpler to say make the minimum leg length at least equal to or more than plate thickness, even though that isn't absolutely technically correct. Maybe I should stop saying that! The problem there though is then I would have to explain throat depth and face shape each time. My replies on here are usually half of a novel as it is!
              Millermatic175
              HTP MIG200
              Purox oxy/ace
              Jackson EQC
              -F350 CrewCab 4x4
              -Bobcat 250NT
              -PassportPlus/Q300
              -Suitcase8RC/Q400
              -Suitcase12RC/Q300
              -Smith oxy/propane
              -Jackson EQC
              • #52
                well, they moved it today (i couldn't get there) and i haven't gotten any phone calls, so i'm assuming it went well.
                unless the guy who would have had to call me when it fell was under it if it DID fall...
                Miller Bobcat 250
                Miller 8VS suitcase
                Millermatic 251
                Millermatic 180
                Miller Spectrum 375
                • #53
                  Im glad it worked out ok, assuming it did.
                  Millermatic175
                  HTP MIG200
                  Purox oxy/ace
                  Jackson EQC
                  -F350 CrewCab 4x4
                  -Bobcat 250NT
                  -PassportPlus/Q300
                  -Suitcase8RC/Q400
                  -Suitcase12RC/Q300
                  -Smith oxy/propane
                  -Jackson EQC
                  • #54
                    You know what they say?
                    If nobody died, it was a good pick!
                    Caution!
