Welding Torch
  • Welding Torch
    Check out the picture. Has anyone ever used one of these and if so, how does it work ? It is an old welding torch that used alcohol as fuel.
    Ken
    What else is there besides welding and riding. Besides that
    Miller Thunderbolt XL 300/200 AC/DC
    Hobart Handler 187
    Dewalt Chop Saw
    4" Air Grinder
    Die Grinder
    Rigid Drill Press
    Kellogg 10hp Air Compressor
    2009 FXDC
    Suspect it may have been used for soldering not welding. Alcohol doesn't produce the heat needed for welding. Plus, there's a lot of moisture produced from burning alcohol.
    If it was as finikey as the old alcohol stoves on boats (preheat and all) I suspect it never became very popular. Anyone on here old enough to have really used one, I'd really like to hear from them.
    Syncrowave 250 DX Tigrunner
    Miller MM 251 w/Q300 & 30A SG
    Hobart HH187
    Dialarc 250 AC/DC
    Hypertherm PM 600 & 1250
    Wilton 7"x12" bandsaw
    More grinders than hands
      I've seen these before hanging on the walls as decoration, never seen them in use though. I would suspect SundownIII is correct in his assessment of the use for solder and not for any kind of welding. I too would like to know more about them and their actual usage, maybe even an actual demonstration. Dave
        Behind the hexagon cap on the top are some small pin holes like you would find on a torch tip. In the larger spout is some kind of wick. The wing type knobs on the side just turn like it is some kind of adjustment. It is about 7" tall. If I can find out how it is supposed to be used, I'll take some pictures for everybody.
        Then again, whats the worst that can happen by experimenting with a pint of alcohol.
        Ken
        Hobart Handler 187
        Dewalt Chop Saw
        4" Air Grinder
        Die Grinder
        Rigid Drill Press
        2009 FXDC
          The next statement after that is usually "It only hurt 'til I passed out". Dave
            The worst that can happen?
            Originally posted by Pyro View Post
            ... but i have welded beer cans and i use more like 18amps or so... however the more beer i consume (to empty the cans) the worse i weld
            Quote from the Motorsports message board.
            On the other hand, for some of us - the more we consume the prettier the beads look.
            That's got to be for soldering, and I think they were used a lot in fabricating the embossed tin ceilings popular at the turn of the century (before last). I've had to repair a few of those in some historical buildings, and nothing in my kit bag would touch those seams until I fabricated a very wide tip for MAPP gas to sweat them.
            I'd definitely be interested in seeing/hearing what anyone comes up with on the use of that puppy.
            Any old-time plumbers to speak up?
            Joe
              I have seen these before and my father had one, although I never saw him use it. I think it was a plumbing tool to use with the cast iron pipe. The seems were filled with lead. I am glad we have PVC pipe now.
              sigpic 6010
              If I had know I was going to live this long, I would have taken better care of myself.
                I just thought of something. Back when these torches were used it was probably easy to get fuel for them. Liquor stills were usually strategically located in the community. They could probably uses these torches for welding, because the stuff they made back then burned a lot hotter than what we have today.
                sigpic 6010
                  "NO", It only hurt when I woke up. "SORRY" wrong kind of alcohol.
                    Try this guy: http://www.blotorches.com/miniatur.html Seems to be a collector of old alcohol torches.
                    Also, I think the alcohol torches they use for wax casting uses denatured alcohol as fuel.
                      I found this on the web site with a picture, exactly like mine. I am going to email them, see if I can get more detailed information.
                      One of the more interesting miniature blow torches is the two chamber alcohol. These came in two flavors, one with a baffle/mix chamber and one without. In the case of the type without a mix chamber, the auxiliary wick must be burning at all times for the torch to work. The self generation can only occur in a torch with the mix chamber/baffle and therefore, once the torch is up to operating temperature, the wick can be blown out. These are very beautiful little torches and they are lit very easily and come up to operating temperature very quickly.
                      Ken
                      Hobart Handler 187
                      Dewalt Chop Saw
                      4" Air Grinder
                      Die Grinder
                      Rigid Drill Press
                      2009 FXDC
                        hey, wow, there is a scene in a John Wayne movie that acutally uses one of these! It is called "The Shadow of the Eagle" and is from the 30's. They used it to "make him talk" in the movie, but it's the same thing.
                          Torch explanation from a professional
                          I received this email reply from the web site. I wanted everyone to see it in case they have a torch like it.
                          Ken:
                          Sorry for the delay.
                          I do not recommend lighting any antique blow torch, gasoline or alcohol.
                          This particular torch is used for light soldering and possibly jewelry repair and other jobs that require a small but hot flame.
                          The two big hex nuts are for the two fuel chambers. One chamber holds fuel for the burner head, where the actual flame comes from, and the other chamber holds fuel to operate the warming wick, which is contained in the capped angular pipe that comes out of the top. The cap prevents the alcohol from evaporating during periods of nonuse.
                          These units use pure denatured alcohol, not rubbing alcohol. Please see my miniature torch section on my website for more information.
                          Ken
                          Hobart Handler 187
                          Dewalt Chop Saw
                          4" Air Grinder
                          Die Grinder
                          Rigid Drill Press
                          2009 FXDC
                            Glad you were able to get some info on the torch, interesting stuff, but I'd still like to see one in use. Dave
                              Since the label is visible in your original photo, have you tried to Google the manufacturer, model name/number, etc.? You might be able to find something that way.
                              By the way, to narrow down your Google search, you might try the following:
                              1. Use " " for exact phrases:
                              "ACME alcohol torch"
                              "ACME Model 100x"
                              2. Use boolean logic, if you understand that stuff (AND, OR, +, -, "):
                              "ACME alcohol torch" OR "ACME Model 100x" - "Wylie Coyote"
                              (which just means, search for ACME alcohol torch or ACME Model 100x without any references to Wylie Coyote)
                              3. Use Google advanced search page:
                              (just fill in the proper blanks and it does the boolean logic for you)
                              Good luck
