I get asked this question alot, which should I use, a grinding wheel or flap disc. My opinion is that if surface finish is not a concern use a grinding wheel (it is cheaper).
However, if the part is going to be painted or is stainless steel use the flap discs which provides a much better surface finish. The grinding wheel tends to gouge the metal and will show through when painting, plating or on stainless.
What do you all think?
By the way, if you use flap discs I have found a great source at Lehigh Valley Abrasives (www.lehighvalleyabrasives.com) $1.72 each for Zirconia flap discs that perform well and last a long time.
