ring/roll bender help
  • Cgotto6
    If you don't know where to get dies, swag4x4 has a bunch online on their website. They have some for angle iron. They are made to work in the harbor freight roller. I purchased their 1 3/4" rollers and it worked great for bending my front bumper support on my racecar. That was .120 wall also.
  • aametalmaster
    Originally posted by coronan View Post
    So browsing this and other threads, I see different styles.
    1. Drive on 1 roll OR Drive on 2 rolls
    2. Removable top roll for removing material.
    3. Adjustable width of the 2 bottom rolls
    What is preferred? (I’m getting ready to make my own)
    Anyone Rolling Angle-Iron?
    2 drivers is always better, less slippage. What size angle? and how tight of radius? Angle would be simple to roll with the right grooves cut into the roll...Bob
  • coronan
  • fun4now
    are you thinking you could corrugate it after its already rolled?? or corrugate it first then roll it ??
    just keep in mind rolling odd shapes will most likely need a matching roll. the HF version i mentioned doubles as a slip roll and a bead roller at one end with the first 2 rolls geared together and the 3rd one adjusts in and out to form different roll diameters as a slip roll. again a pretty simple design once you see it you will think, "man thats too simple to work" but there is not much to it really.
    good luck and keep us posted when you start your build.
  • aametalmaster
    Clint, I think you are on a roll now. I get my steel from a local steel supplier and sometimes i don't think he knows what he has but it was regular Cold Rolled Steel but it didn't cut like CRS so it was prob something else advertised as CR. There is a big bar mill right up the road so i am assuming it may be from there. If i was going to make a wider one like you need i would use a better grade of steel like Stress-proof C1144.
    http://www.metalexpress.net/cgi-bin/...42002c055cc0f2 You can look around here....Bob
  • BWS29128
    Originally posted by aametalmaster View Post
    I made these 3 rollers from 3" CR for about 100 bucks and postage was only 9 bucks. The steel cost me 75 bucks...Bob
    Bob,
    What "variety" of steel did you use for these? You made them on your own lathe? What is "CR"? Chromoly? Which version? Are each of those a single piece or is the shaft through the middle welded to the rollers? GREAT info from you and Fun both!! I'm still sorting all the different ideas; I think you're probably correct in that I'm going to have to have two machines, and if so, I think I'll go ahead and get a 3rd machine as well for purchasing large quantities of 12ga or smaller in rolls and then unspooling/shearing depending on what size pipe gets ordered. Then through a corrugater, then through a roller. I may even try to branch out into various corrugations so that I could sell corrugated siding as well (for barns etc.).
    ~Clint
  • fun4now
    a little food for thought. ring rollers like the one i have are for solid stock. as are slip rolls with flat rollers. you can use shaped rollers to bend shapes, but flat ones will deform hollow stock. i added a few pic's to show the results for those looking to buy.
    if you get the rollers shaped to the stock, hollow is doable.
  • fun4now
    i was lucky enough to run a metal lath once way back. talk about a great tool. time consuming but man the possibility's. man how cool it would be to have one in the shop.
    i downloaded the owners book for the slip roll from HF hoping it would show the makings but its not the best parts breakdown sheet and as such dose not have much to offer.
    i did add a pic of a different roller option and a quick (not so great) drawing of the breakdown of mine. i'll see if i can come up with some more useful drawings or plans.
    maybe starting a thread on slip rolls would get more of the guys that made slip rolls involved.
  • aametalmaster
  • Bert
    cheap, huh????
    For those who have asked for a few more pics. I have an album full of them somewhere in cyberspace but i can't find them. I can make rollers for anyone that wants them, cheap...Bob
    Ok, let's see how cheap How much and for what capacity do they do?
    Maaaayyyy be "slightly" intrested
    thanks,
    bert
  • aametalmaster
  • fun4now
    take a look at this.
    http://www.jhchoppers.com/
    JH Choppers put up a set of prints and pic's of the slip roll they made. he got the plans off the hobart board so he is giving them out. the pic's and plans are a lot closer to what you are looking for i think than the ring roller i have.
    i think you will find it well worth a look.
    if the link takes you to his home page, just click on the Tools link on the left and you will be there.
    cant wait to see the one you make . be shore to share pic's
    as a bonus he has some nice bikes to look at too.
  • BWS29128
    I got interested in this thread because I'm thinking of building my own sheet roller. Even more, I'm thinking of building one that will handle a full 4' X 8' sheet of 12 or 14 gauge aluminum so that I can "roll my own" pipe. So not only would I be building my own sheet roller, I'd have the 3 rollers custom lathed so that the finished product would be corrugated. The M.E. I spoke with who owns the lathes said he could make what I wanted out of tool steel and they wouldn't be that much money. I can make my own stand and wire my own motor. I may have to buy a hand-operated 22ga capacity "cheapie" to copy the design on, but other than that I'm just exploring ideas. This pipe project I'm doing has turned into a major P.I.T.A. and I'm looking at different alternatives to trying to mate up spiralweld and annular ring pipe.
  • fun4now
    one more, sorry i couldn't decide on witch of the last 2 were a better view.
  • fun4now
    being as you are booth looking into the same thing i'm just going to add the pic's of mine for BWS29128 here as he is looking to make his own. i got the cheaper version in the link below or one similar to it. mine was $69 + shipping when i got it. steel prices and shipping gone up, go figure.
    http://cgi.ebay.com/Sheet-Metal-Band...QQcmdZViewItem
    any how i added a ring around the 4 piece handle as it really dose not work well as is. its just not a working option IMO. it will get the job done, i used it as it was new to make my ring for it. its just really hard to keep a steady roll going with only 4 small contact points. thats most likely why the shop outfitters is sold with a ring. i highly recommend using all thread for the ring as it gives great grip in gloves or out.
    any how as he is looking to build one i took some better pic's of mine for him. BWS29128 PMed me about it. i'm purity shore i have some pic's of some slip rolls made by members also and will try to locate them and add them in later. kinda got a house emergency going on at the moment.
    its a simple design that should be east to duplicate. if i get some time i'll take mine apart a little more to show the individual pieces.
    hope the pic's help
