are you thinking you could corrugate it after its already rolled?? or corrugate it first then roll it ??
just keep in mind rolling odd shapes will most likely need a matching roll. the HF version i mentioned doubles as a slip roll and a bead roller at one end with the first 2 rolls geared together and the 3rd one adjusts in and out to form different roll diameters as a slip roll. again a pretty simple design once you see it you will think, "man thats too simple to work" but there is not much to it really.
good luck and keep us posted when you start your build.
