Deck Gate
  • #16
    A Ranch Way is the thing that goes over the entrance to the ranch that has the name and brand of the ranch on it. Many are arched steel, but some people just use telephone polls. Here in Colorado many people use large cedar poles and they look good too. I have to do one for "South of the Border" and one for "Hill Top", both in TN.
    • #17
      monte
      hey monte did u do those in your propane forge?Did you buy it (the forge) or make it yourself?Id luv to get my hands on one just to try my hand at making some cool mideival armor and helmets.
      • #18
        Originally posted by monte55 View Post
        Hey guys.........don't you know a girl when you see them?(the darker one)
        The shy white one is a boy that we rescued from Huntsville Alabama in October 2004,...700 miles away. Of course all you can see is his ears. Before I went to get my camera, all 3 were pressed against the gate which would have made a good pic. Why is it they do all their cute stuff when the camera is not in hand. I think they heard my wife tell me to get the camera and then I heard a bark which means "RUN". I'm not sure but can only assume.
        The scrolls are 1/2" and so are the pickets.........
        Yes, I made the rings which are 1/2 " also......I have a picket twister I made about 5 years ago and if I put a 3" mandrel on it with a catch dog, I can start a 20' piece of round or square and have it roll up like a coil spring, then cut off rings as I need them, close them in a vise and weld them.
        The dogs are well behaved unless you bring them into the house but the play
        is still in the dogs. They should have a PLAY METER on them.
        Thanks for the looking.
        Nick or is it Monte? I saw Nick on your signature line. I like your gates, but I like your dogs more. My family is hooked on dogs. We have three Cairns and they are a part of our family. Can you post how your picket twister is able to make rings, and some photos? Nice work!
        Thanks,
        Nick
        • #19
          I purchased the forge from a guy used but in perfect shape about 6 years ago for $300. It's from Centaur Forge, thinks thats the name, and yes, it uses propane and propane accessoriesNew ones are $500-$600.
          I'm not sure but I think the model is something like Wisper Daddy. My catalogue is in the shop and I'm not now.
          monte55
          Nick
          Miller 252 Mig
          Miller Cricket XL
          Millermatic 150 Mig
          Miller Syncrowave 200 Tig
          2-O/A outfits
          Jet Lathe and Mill
          Jet 7x12 horz/vert band saw
          DeWalt Multi Cutter metal saw
          Century 50 Amp Plasma Cutter
          Propane Forge
          60" X 60" router/plasma table
          • #20
            Hey Monte,
            I wondered if you missed my post on the picket twister, and the ability to fabricate rings.
            Thanks,
            Nick
            • #21
              Originally posted by kiwi View Post
              Hey Monte,
              Thanks,
              Nick
              Sorry, been a bit busy. First chance I get. I'll take some pics of the twister.
              Nick
              Miller 252 Mig
              Miller Cricket XL
              Millermatic 150 Mig
              2-O/A outfits
              Jet Lathe and Mill
              Propane Forge
              • #22
                Thanks,
                Nick
                • #23
                  Some other pictures of our Chows that ducked out when I tried to take pictures of the gate with our Chows peering through. The picture of the black dog is a picture of a picture because he chose to stay inside while I was taking pictures. We rescued him also in 2004 from a local Rescue; a few months prior to adopting the white Chow from Huntsville, Alabama. which we rescued in Oct, 2004.
                  Nice looking Dogs - gates look good too! Glad there are people like you to rescue these animals
                  Never trust a man who doesnt own a dog!
                  • #24
                    One thing about adopting a dog. If they start to misbehave, you can always threaten them saying they'll go back to the home if they don't straighten up. Idle threats, I might add.
                    Nick
                    Miller 252 Mig
                    Miller Cricket XL
                    Millermatic 150 Mig
                    2-O/A outfits
                    Jet Lathe and Mill
                    Propane Forge
                    • #25
                      Kiwi, Pics I promised for you and others if interested..
                      Hey Monte,
                      Thanks,
                      Nick
                      Here are some pics of the twister. The gear box is a 41 to 1 ratio running a
                      1/2 hp 1725 rpm 120 volt mtr. The base is an I Beam which works well for clamping and is very rigid. When we first made this, we had marks on the gears, and started and stopped the machine manually. If you had a good day and your timing was good; no problems. But, under twisting or over twisting is a real pain. So I ended up making a micro switch assembly so once I turn on the power I push a button once for one revolution. If I want a double twist, I hit it twice, etc. The mandrel that the pickets slide into is a
                      half inch drive socket welded onto a tube, which as you will see in the picture, has different stops for various lengths of pickets.
                      Below are some stills of the machine and rings that have been made. The size of the rings obviously depend on the size of your mandrel. Also, I am supplying links to a couple videos of the machine in action.
                      Don't complain about the quality of the video and pics as these were done in a hurry but I think you will get the idea.
                      http://www.youtube.com/watch?v=O9l4mgE-MDY
                      http://www.youtube.com/watch?v=i0W1J7XIaRs
                      monte55
                      Nick
                      Miller 252 Mig
                      Miller Cricket XL
                      Millermatic 150 Mig
                      2-O/A outfits
                      Jet Lathe and Mill
                      Propane Forge
                      • #26
                        Hey Monte, I know we're being a pain, but can you give us a list of materials for the machine?
                        • #27
                          Monte,
                          video was cool, nothing wrong with that!!!!!!!!!!
                          thanks, you make some cool tools!!!!!!!!!!!!!!!!!!!
                          I'm not late...
                          I'm just on Hawaiian Time
                          • #28
                            Tried that with my wife one time but it didn't work
                            Ken
                            Hobart Handler 187
                            Dewalt Chop Saw
                            4" Air Grinder
                            Die Grinder
                            Rigid Drill Press
                            Kellogg 10hp Air Compressor
                            2009 FXDC
                            • #29
                              that twister is great. do you have it set up to do 1 rotation and stop or run cont. or did it stop after 1 turn for some other reason??
                              you must make a lot of stuff to put that kind of tool together, but man it must be nice to have now.
                              sigpic
                              • #30
                                It's turns off after i revolution. If I hold the button in, it will continue to run.
                                And yes, it has twisted many pickets.
                                Nick
                                Miller 252 Mig
                                Miller Cricket XL
                                Millermatic 150 Mig
                                2-O/A outfits
                                Jet Lathe and Mill
                                Propane Forge
