metal band saw recomendations
  • metal band saw recomendations
    Hey guys, I'm wanting to buy a vertical metal band saw for my shop and I would like to know what model and brand is most people using. I cut everything now with my sawzall in a vise and I'm wanting to let loose of my caveman habits and step up to some modern cutting equipment. I cut alot of aluminum sheet, tubing for headers, aluminum tubing etc.etc..... I see Jet is a popular brand and has alot of options to choose from. I'm just curious what you guys have and how well you like them.
    Gary
    ______________
    MM-185
    Dynasty 300DX
    Thermal Arc Arcmaster 200
    hey cant go wrong with jet. i used to own one forgot the model but i fine machine.
    Millermatic 210
    dialarc 250
    spectrum 375x
    trailblazer 302
    Lincoln 135
      I use this one: HVBS-56M, 5" x 6" Capacity Bandsaw, 1/2 HP, 1Ph, 115/230V
      Model Jet 414458
      It sure beats the Horrible Fright model that it replaced.
      I also use a chop saw and a Milwaukee dry cutting saw.
      Millermatic 211 AutoSet w/MVP
      Century 110 volt 90/110 MIG-Gone to my son, in Texas
      Victor SuperRange OA
      Milwaukee Cold Cut Saw
      Milwaukee Portable Deep Cut Bandsaw
      Milwaukee Hole Hawg
      Jet Horizontal/Vertical Bandsaw
      Jet MD-18 Mill Drill
      Orbit Drill Press
      12 Ton Floor Press
      2002 E-350 V-10:
      1983 F-150 4.9L 6
      2004 Honda ST1300
      2007 Suzuki LTA400F Quad
      1997 Suzuki DR650
        I don't own one personally, but look into Grizzly, they've got pretty good prices and China quality similar to Jet.
        Miller Syncrowave 200
        Homemade Water Cooler
        130XP MIG
        Spectrum 375
        60 year old Logan Lathe
        Select Machine and Tool Mill
          Something I didn't understand about my 15" vertical band saw. The 15" means throat depth (yes I knew that part). But if I want to cut a 16" piece off of a 10 footer, I can't use it. It works well for the smaller hand controlled cuts, though. As soon as I got one, I wanted another one. I think there may be a swivel head horiz. in my future.
          RETIRED desk jockey.
          Miller Syncrowave 250.
          sigpic
            You can do it, just not with one cut. Make the first at an angle and a bit longer and then clean it up on the second. I do it quite a bit because I don't feel like using 2 saws.
            Miller 30-A Spoolgun
            Miller WC-115-A
            Miller Spectrum 300
              craig,
              15" refers to the diameter of the wheels that drives the blades.
              that leaves the throat depth is always a little bit less than the wheel diameter.
              just some almost useless info.
              think there are some horizontal/ vertical combination machines.
              i have some jet machines, sure that they are all made in china.
              They are ok though, build quality was acceptable.
              a "value" machine
                I have a swivel head saw and I love it. It was especially useful when I had to cut steel at a 28 degree angle for my porch railing project. Attached is a link to the saw.
                http://www.accuramachinetools.com/ac...ad-metal-.html
                Here is a link to a discussion about swivel head saws. My post is #11 on page 2.
                http://www.millerwelds.com/resources...ghlight=swivel
                Now I would like to get a vertical metal cutting saw.
                Miller Thunderbolt
                Smith Oxyacetylene Torch
                Miller Dynasty 200DX
                Lincoln SP-250 MIG Welder
                Lincoln LE 31 MP
                Lincoln 210 MP
                16" DuAll Saw
                15" Drill Press
                20 Ton Arbor Press
                Bridgeport
                  Yeah, just for some persepective...
                  I got rid of my HF band saw when I realized how easy a dry cut saw made things. I paid $279 for a Milwaukee 6190-20 on ebay, and Freud Diablo blades are about $30 each. I made 181 cuts for a fence this afternoon in about an hour and a half, and the blade is still cutting like it's new.
                  Jack Olsen
                  The Garage(And its slideshow)
                  The Car(And its slideshow)
                    When I found my 7x12 Wilton I gave away my 6" HF style because I felt they were too close to the same thing. Mistake
                    The little saw with the narrower blades can do more in the vertical position.
                    My "go to" saw is actaully nothing to brag about. It is a Delta 14" wood bandsaw for $299 at Lowe's. I slapped a 10 tooth Lennox blade on it and it is just flat perfect for the money. Works fabulous on aluminum.
                    You would need to slow it down for steel or just get a better saw from Grizzly with bearings on the blade guides. That's what I will buy after this one is shot.
                    Miller WC-115-A
                    Miller Spectrum 300
                      Gentlemen: thanks for the tips and links.
                      FK:
                      Sheesh, sometimes the answer is too simple; cut twice. Saving the money isn't as important as saving the floorspace.
                      sigpic
                        jet is good
                        ive got a jet vert and horz, i love them, the vert saw will come in so handy, i find myself using it for all kinds of things, most of which arent for the purpose i bought it for, you will be pleased
                          Originally posted by gordfraser View Post
                          craig,
                          a "value" machine
                          I have a 16" Delta vertical band saw. It has a 16" throat and 3 wheels......none that are 16".
                          Nick
                          Miller 252 Mig
                          Miller Cricket XL
                          Millermatic 150 Mig
                          Miller Syncrowave 200 Tig
                          2-O/A outfits
                          Jet Lathe and Mill
                          Jet 7x12 horz/vert band saw
                          DeWalt Multi Cutter metal saw
                          Century 50 Amp Plasma Cutter
                          Propane Forge
                          60" X 60" router/plasma table
                            Sounds cool...got any pics? (Too lazy to search thru the internet)
                            Miller WC-115-A
                            Miller Spectrum 300
                              Gary
                              Have you thought of getting a Horizontal/Vertical cutting saw.? That way you get the best of both worlds.
                              Bob
