Gantry Crane
  • Gantry Crane
    To help my company make ends meet we all had to take a four week vacation without pay.
    For two of the weeks I helped my brother to fabricate and install a ½ ton overhead crane in his shop which will be used to help him to move material from his shop floor to his loft. The design involves an electric winch that is attached to a trolley that runs on a 25 foot I-beam. The I-beam is supported in the middle with a cross beam.
    Miller Thunderbolt
    Smith Oxyacetylene Torch
    Miller Dynasty 200DX
    Lincoln SP-250 MIG Welder
    Lincoln LE 31 MP
    Lincoln 210 MP
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
    Wow Looks Great.
    What wall thickness is the center beam.
    Hope you can find more work during your vacation.
    g6Racer
    Miller Dynasty 200 DX
    Miller Spectrum 375 X-TREME
      That sure beats carrying materials up the ladder..
      Bob
        The center beam was 1/4" thick.
        Miller Thunderbolt
        Lincoln LE 31 MP
        Lincoln 210 MP
        16" DuAll Saw
        15" Drill Press
        20 Ton Arbor Press
        Bridgeport
          Monorail
          Pictures look more like a monrail, instead of a gantry??
            Yes that is a monorail and not a gantry.
            Good looking job.
            Hopefully your building was built with a snow load factor to carry the additional weight.
            Try not to use the crane in the winter if you have snow on the roof, otherwise you should be ok.
              Good looking job.
              Thanks. I was wondering what to call it. Monorail makes more sense.
              My brother's shop is located in southern Virginia, just north of Greensburg North Carolina. The building has a generous snow load but rarely has very much snow. As you pointed out, he was planning on not using it if there is snow on the roof. The "I" beam is designed for 1/2 ton but the electric winch that he currently has on it is rated for 1/4 ton instead of 1/2.
              Miller Thunderbolt
              Lincoln LE 31 MP
              Lincoln 210 MP
              16" DuAll Saw
              15" Drill Press
              20 Ton Arbor Press
              Bridgeport
                Bob
                It’s funny that you should mention ladders to the loft. While at my brother’s place I also welded together a stairway to the loft. He had some 10’ stair tread stock that we cut up into 3’ treads. Attached is a picture of my brother and me next to the stair channel fabrication. I’m the one the right. In the second picture my sister in law is modeling the completed stairway.
                Miller Thunderbolt
                Lincoln LE 31 MP
                Lincoln 210 MP
                16" DuAll Saw
                15" Drill Press
                20 Ton Arbor Press
                Bridgeport
                  He's Not Heavy He's My Brother
                  That is a nice looking staircase,can't miss the lime green color. I still say the same thing It beats carrying materials up the ladder. You guys done a great job..
                  Bob
