Has anyone used that HF large radius tubing bender? I would be using it for light fabricaton projects on mild steel from .065 to .095 wall. Was wondering if it worked ok and how it held up to use.
Harbor Freight Tubing Roller
i've been eyeing that tube roller for a while now. i want to roll some .120 wall tube for some handle bars. i'm leaning more towards building my own heavier version for the simple fact that i have the scrap steel to do it. plus i don't know if that one will bend .120.Matt
Syncrowave 200
Thermal Dynamics Cutmaster 52
Smithy Midas 1220 Lathe- Mill
Bandsaw- 20 yr old Harbor Freight type
Speedglas
I looked at it the other day myself and was considering it. Seems the dies alone would be worth the money. The tool seemed to be of only fair construction quality, like most stuff they sell. When I left the store I was wondering if China had stores full of crap made in the US?Miller Syncrowave 200
Homemade Water Cooler
130XP MIG
Spectrum 375
60 year old Logan Lathe
Select Machine and Tool Mill
Originally posted by nocheepgas View Post. When I left the store I was wondering if China had stores full of crap made in the US?JUST KIDDING!! no hate mail please
Syncrowave 200
Speedglas
Originally posted by urch55 View PostAs a person brought up on another thread. Are you talking about a tubing or pipe bender.??
Bob
http://www.harborfreight.com/cpi/cta...emnumber=99736Ed Conley
MM252
MM211
Passport Plus w/Spool Gun
TA185
Miller 125c Plasma 120v
O/A set
SO 2020 Bender
You can call me Bacchus
Large radius "bends".Ed Conley
MM252
MM211
TA185
O/A set
SO 2020 Bender
The quality of these units are less then stellar. For once in a while use for less than exacting work I think that it would work on thin stuff.
The reason is the sides are pretty thin material and the top plate is thin as well.
The rollers are on ball bearings.
I have some vintage (3 of them) wagon wheel benders that can be used for solid bars. And these work great. They are all Cast iron work horses.
The tubing benders by JD and a few other company's would be a better bet for Crome moly tubing. as the dies are designed to keep the tubing much more round then simply flattening on the sides to create the bend.
Originally posted by allessence View PostThe tubing benders by JD and a few other company's would be a better bet for Crome moly tubing. as the dies are designed to keep the tubing much more round then simply flattening on the sides to create the bend.Miller Syncrowave 200
130XP MIG
Spectrum 375
HF Tubing bender
Originally posted by Shamrock1123 View PostHas anyone used that HF large radius tubing bender? I would be using it for light fabricaton projects on mild steel from .065 to .095 wall. Was wondering if it worked ok and how it held up to use.
They also have a set of dies for the machine for square tubing. I sprung for a set of them (@ $49.95) and I was impressed with the bend there as well. So far they only have them for 1/2" square tubing. I don't know if they will go to bigger tubing (and if not, I don't know why not).
A friend came to my shop and wanted to bend a large circle out of 1 1/2" X 1/4" strap. I didn't have the square tube dies then, so we centered it on a round tubing die. It took a little effort to keep the material centered but we prevailed and the bender made a very nice base for a stand he was wanting to build.
I expect to get good service from the machine. The sides aren't very thick, but they are in tension and it seems to be enough. The dies are pretty hefty.
Somewhere I may still have the 1' tube and the 1/2" square I bent. If so, and there is interest I can take a photo.
John
