I work for a municipality and one of the local cops came to me today to ask me to do a project. I do all the welding for the municipality but this project Im not sure about. They have a Ford Econoline van equipped with armor plating on the inside. They want running boards on the outside along with rails to hold onto. The cops want to be able to hang on the side as they roll up to make a bust so they can just jump off instead of climbing out of the van. Average weight per cop with all gear on is 300 lb. The running boards are not a problem. I can use diamond plate or whatever and bolt it fast to the frame. My biggest problem is the handrail. With the armor inside, there is no way to get to the inside of the sheet metal. To screw it fast or weld it fast just doesnt seem strong enough to hold 3 or 4 cops holding on. Im open to any suggestions or ideas to someone that has been welding longer than myself. I was only at it about 5 years now, got into it too late in life.
Difficult Project
KBar, The only easy solution I can see would be to attach the grab rail into the running boards with some tall uprights, kinda like a hand rail on a walkway railing with out all the pickets in the middle. DaveIf necessity is the Mother of Invention, I must be the Father of Desperation!
KBAR,
Can you possibly tie into the roof and bring the support to the side. I suspect that although the van sides are armor plated the roof isn't, unless of course it was designed to give overhead protection.
Does the van have the split doors or the one sliding door. If it's sliding, Dabar's idea of tieing into the running board may not work. The higher it is, the more support it will give to standing cops. Thats why, on some of the larger boats, you'll see a handrail mounted in the ceiling and running the length of the salon.
Just a thought.Syncrowave 250 DX Tigrunner
Miller MM 251 w/Q300 & 30A SG
Hobart HH187
Dialarc 250 AC/DC
Hypertherm PM 600 & 1250
Wilton 7"x12" bandsaw
More grinders than hands
KBar, SundownIII, My idea was to bring it up over top of the doors if they opened out or far enough away from the side if it's a slider. I was just trying to do a half a$$ed sketch on the computer but it wont let me transfer the file from paint for some reason. but anyways my idea was to bring it up to the top of the van sides. I didn't think about the roof idea as I wasn't sure about how the plating was inside the van, but you may be able to attach something like SundownIII suggests and brace it off of the drip rails. DaveIf necessity is the Mother of Invention, I must be the Father of Desperation!
I like Sundowns idea if I got it right.
The armor plating is on the floor as well as the ceiling. Im getting a key to it next week so I can look inside and try to get a feel for any spacing between the armor and the sheet metal. It does have the sliding door so I dont think fastening the rails to the running board will work, on that side anyhow.
Sundown, was your idea like running 3 - 3 inch straps across the roof, screwing them fast if I can find the roof supports, then fasten the rails to that with the rails running along the drip edge ?Ken
What else is there besides welding and riding. Besides that
Miller Thunderbolt XL 300/200 AC/DC
Hobart Handler 187
Dewalt Chop Saw
4" Air Grinder
Die Grinder
Rigid Drill Press
Kellogg 10hp Air Compressor
2009 FXDC
KBar,
If the ceiling is indeed plated, I'd probably cut two holes in the roof and weld a support directly to the inside armor (assuming it's strong enough). A little sheet metal cut to fit around the support (the one you weld to inside armor), and you've got the hole sealed.
Then after mounting the center supports, you can bring the straps to the side where you would weld the grab rail. Actually seems pretty simple.Syncrowave 250 DX Tigrunner
Hobart HH187
Dialarc 250 AC/DC
This rig has handrails for the officers... although it's not an econoline van.
The support coming from the roof would be best I think because it will be easier for them to hold on. Trying to hold on with a hand hold shoulder high or lower will be more difficult, especially with all that gear on.
But looking at this from a distance I wonder if what they want really makes sense. They are not protected by the armor outside. They may find they didn't have the element of surprise and wish they were inside the vehicle. I know in a drug bust situation there will be a lot of excitement and Adrenalin flowing. I can see the driver blasting through a gate without enough clearance on the side scraping off come of the officers. He may have to drive close to a tree or hit a big bump. Another vehicle may even hit them. The worse thing that could happen is getting to the drug bust with half the people missing. I think they would be much better off practicing the exit routine. They may be surprised how proficient they can become at jumping out. Just my humble opinion.sigpic 6010
If I had know I was going to live this long, I would have taken better care of myself.
6010, I agree with you 100% but if you ever talk to an officer, they know best. They are too much of a target on the side if the criminal is holed up and using fire power.
Besides I think they watch to much TV sometimes and want to be like the Bad BoysKen
Hobart Handler 187
Dewalt Chop Saw
4" Air Grinder
Die Grinder
Rigid Drill Press
2009 FXDC
Your top rails could bend over the edges of the van like a swimming pool ladder or something similar.
If all else fails, SundownIII's idea would work...maybe using 1" X 1" X 1/4" square tubing and then using SQT straps across the tubing bolted down into the armor. With your vertical and/or horizontal grab rails attached to them.
I doubt your cops are gonna ride all the way from the station like that, so they'll probably just stage a block away from the bust or something. Standard running boards (reinforced for additional weight) would work fine. And that leads me to another idea (sorry...still absorbing my first pot of coffee of the day):
How about JUST using a horizontal bar as a handhold running lengthwise down each edge of the roof of the van? and then attaching said bar to straps or tube across the top of the roof in one of the aforementioned ways?
Okay...I'll shut up now.sigpic
Clint Baxley
Baxley Welding Service
Rembert, SC 29128
Links To Pictures of SWAT Handrails
Here are links to a few ideas:
http://rides.webshots.com/photo/2811...72832045jLHSsq
http://rides.webshots.com/photo/2562...72832045ZVqBTL
http://rides.webshots.com/photo/1488...72832045nCZwkK
Just some ideas for handrails.sigpic
Clint Baxley
Rembert, SC 29128
why not run from one running board over the top to the other running board in the front and rear of the van with a pipe then add one at holding hight between the 2 to add handles to or to use as a handle if you curved it out from the van a bit. if you are concerned about the driver forgetting they are there add a crash bar into the front hoop to the width of the running boards or to there spec's. see pic.
the armor plaiting is most likely intended for evacuation of wounded and or civilians. i don't think they generally go in for a drug bust under fire gun's a blazing. too much risk to others as well as themselves.
my first thought was also to come off the ceiling but if its not an option why not just encircle the van like a outside role cage and build from that. would also give it a cool sturdy look they might like.
dabar39 after you draw it in paint save it as a JPEG and then you can load it up. might have to resize first but it works.Attached Filesthanks for the help
[email protected]
Originally posted by fun4now View Postwhy not run from one running board over the top to the other running board in the front and rear of the van with a pipe then add one at holding hight between the 2 to add handles to or to use as a handle if you curved it out from the van a bit. if you are concerned about the driver forgetting they are there add a crash bar into the front hoop to the width of the running boards or to there spec's. see pic.
Fun, I did that and it said something about unsupported file when I tried to load it.If necessity is the Mother of Invention, I must be the Father of Desperation!
Why couldn't you build something like a roof rack that clamps to the drip edge of the van. It would save cutting holes in the roof, [you would have to seal up holes]and could be all one piece out of tubing. You could paint it off the van and clamp it it on. Or for that matter, modify and excisting roof rack to extend down, over the sides. They are adjustable and could be transferred to another unit latter on. Show us pics when doneLast edited by HMW; 09-07-2007, 07:59 AM.Scott
HMW [Heavy Metal welding]
