Motorcycle Paint Stands
  • Motorcycle Paint Stands
    We made some motorcycle paint stands to hold a tank, rear fender and front fender. The stands are generic and can telescope up and down. Then custom mounts were made for each type of part. So when a different type of part needs painting, all we need to do is make a new mount for the part.
    The Generic Stands
    http://www.jhchoppers.com
    The Custom Mounts
    Stands with Parts ready for primer
      Paint Completed
      Paint Completed with the help of new statnds
        Awesome paint job! What technique did you use for the marbling?
        Miller Syncrowave 200
        Homemade Water Cooler
        130XP MIG
        Spectrum 375
        60 year old Logan Lathe
        Select Machine and Tool Mill
          nice job on the paint.. .is that the Alsa Corp. Stuff?
            it's usually done with a plastic bag and marbleizer. Nice work BTW, it looks fantastic. House of Kolor has info on their site I believe
            "When using Marblizer, try applying it in layers to create depth. Spray your first layer of Marblizer and use a thin millage plastic such as plastic wrap to achieve a fine tight pattern in your first texture effect. Allow 30 minutes to dry. Apply a second coat of Marblizer, and this time use a thicker plastic such as a painter's drop cloth to create a larger texture pattern allowing you to see the finer pattern underneath. This gives a lot of depth to your paint finish. You could also use different colors of Marblizer for each layer. Be sure to do a test panel before painting you project."
            https://shop.houseofkolor.com/hok/products/shimrin.jsp
            DYNASTY 200SD
            COOLMATE 1
            MM140AS
            SPOOLMATE 100
            SPECTRUM 625 X-TREME
            SPECTRUM 125C
              Looks like the stands did their job in order for you to do yours. I was thinking what my truck would look like with a paint job like that. Then FLASH I think the paint job would cost more than the truck is worth..
              That is one great paint job.!! If you want to experiment I have a truck for a test subject.
                Thanks !!
                Yes, the trick with the flames is HOK Marballizer. Then Kandy Cobalt Blue airbrushed on the tips and feathered out. The Red Pin Stripe makes it jump.
                This was the first time using the new stands, the height addjustment feature was great. Paint stands sell for big bucks, so if someone looking to make some bucks on eBay, here is your chance....
                Thanks again,
                Joel
