I am thinking about purchasing a new mitering head horizontal bandsaw, I been on the internet searching all brands,capacities, specs etc.,looking for a 8-9" round capacity.There are several brands to choose from, Jet, Wilton,Saber,these seem to be in my price range $1400-2000 range, any one out there have one of these, need some advice,!
/22x45 concrete slab with 2 overhead cranes(trolley style with electric hoist, huge shade tree to weld under
33x33 enclosed shop when its to cold or windy outside
miller 210
miller 875 plasma
victor oxy/accet
unihydro 45ton ironworker
miller 180 tig
ole lincoln ac/dc buzzbox
milwaukee power tools
and everything in between
2007 trailblazer 302
Bailiegh 210 miter saw-2008
Beer Fridge
6000# cat forklift
36" port-a-cool fan
Dake G-75 Belt grinder
3035 Spoolgun
I have one. Its a horizontal bandsaw. I paid 1200 CND. I like it. Its a bandsaw too. The table is a little hoakyas you will see. The head swivels between, - 10 and about +190 degrees.
It has a 3 speed gearbox that can be switched in the fly. Its a nice rig I like it alot. Its made in Tiawan though. So... if you dont mind the offshore thing....
Miller 251/30A spool
Syncro200
Spectrum 625
O/A
Precix 5x10 CNC Router12"Z
Standard modern lathe
horizontal 7x12 bandsaw
Roland XC540 PRO III
54" laminator
little dog
I see that I will need to take a couple more pics... I'll be back.
Syncro200
Spectrum 625
O/A
54" laminator
little dog
Nice saw. The pics are way too big, though. You should resize them so you can actually see the whole thing. I used Irfanview, a freebie, to do this resize. The new size is 480 x 640 and much easier to view....fwiw. They also load much faster at 55kb vs over 300kb.
Its called a "swivel" Give me until Sunday and Ill post some more pics. Im done for today. need sleep zzzzzzzzzzzzzz
Syncro200
Spectrum 625
O/A
54" laminator
little dog
It should fit your bill, and is about in your price range. It is a top quality saw, will last you for years. Here's the 2nd best price I've found on one. The best was $2195 + shipping from southern MN, but he doesn't have an ad up right now:
Syncro200
Spectrum 625
O/A
54" laminator
little dog
at the plant, we use a WellSaw it is a real good machine. the one we have is a little bigger than what you spec'd but you should check them out. we also have a khama bandsaw for fast production cuts. it is extremely fast, faster than a multi-cut saw, which i was hard to believe. proof is in the pudding, i guess. i don't know the sites for either saw. we get them from the lws
Bert, the vast majority of the saws in that class are wet cutters. The 4x6 and 5x6 are dry cuts. When you get up to the heavier industrials, they have to be wet or the blade will not last long at all.
Did you mean dry?, Am I missing something? I saw a jet at a local store, I think it's a 7x12 wet or dry for $900. I LOVE the feature of making it vertical also!!!
thanks,
bert
Maybe I should have said Wet/dry. When you get up to the med sized Ellis and Wellsaws, they be wet. All of the ones I see in operation are only wet. Saves on everything.
thanks,
bert
Bert.........I have that saw and have no complaints
Nick
Miller 252 Mig
Miller Cricket XL
Millermatic 150 Mig
Miller Syncrowave 200 Tig
2-O/A outfits
Jet Lathe and Mill
Jet 7x12 horz/vert band saw
DeWalt Multi Cutter metal saw
Century 50 Amp Plasma Cutter
Propane Forge
60" X 60" router/plasma table
Monte, THANKS! Good to know!
DDA52, if it's good, why not get a wet/dry one? why dry only?(that's what I saw on the first post and the links that were given. I would think the industrial one cut at the same speed. Hmmm.. is it cause we don't cut as much? so, if we cut it dry, less mess and the saw blade will last long enough where we won't complain? If we cut more, use the wet option?
thanks,
bert
