Branding Irons
  • Branding Irons
    Ok fella's, who can give me some tips for making up some sets of branding irons (hot irons). I need a full set of numbers and letters as well as a couple custom irons. I've never made any irons before but I know a few of you have. What are the do's and don'ts? Thanks guys.
    Oh, btw, if anybody knows of a pipeline kicking off, maybe you could let me know....
    i just made mine out of 3/8" flat strap heated and shaped to how i want it then welded the handles on. been using the same ranch brand and number set for i dont know how many years. horses getting freeze branded now only the cows are getting smoked
    MM 251
    DYNASTY 200DX
    SPECTRUM 625
    STARTS AND STRIPES BIG WINDOW ELITE
      Did you notch out the corners to prevent blotching? How about the freeze brands, stainless or carbon?
        could you explain this freeze branding?
        This is an automotive discussion forum that has some great infromation
        www.autobodytoolmart.com/shoptalk
          Freeze branding is basically the same as hot branding but instead of heating the irons, you super cool them. Instead of burning the hair and hide, it freezes the pigment folicles in the hair but not the growth folicles. So unlike a hot brand you get white hairs in the shape of your brand. This is done allot on horses, but not much on cattle. Actually some states don't even recognize freeze brands on cattle.
            on the corners i just took a triangle file and relived out the corners
            i used copper bus bars i had from work for my freeze brands welded them togethor with the tig machine
            for freeze branding the brands are dipped in liquid nitrogen or a mix of broken up dryice and 99% alcohol
            the Liq n2 works better -210deg C as solid co2 is -78.5deg c also theres less infection risk and faster healing times with freeze branding. theres a couple show cattle barns i have built freeze brands for since it looks better also. you can get more detailed information in a small freeze brand thats why the blm uses it for the mustangs and burros
            oh yeah bbj good name....
            MM 251
            DYNASTY 200DX
            SPECTRUM 625
              irons!
              I made a set this spring for a rancher, I posted the pics, take a look and see if it helps!
              DODGE 1 TON 6.7
              PIPEPRO 304
              TO MANY TOOLS
              JUST WELDING IN CIRCLES
              rig welders are like wheelbarrows hard to push around
              and easily upset
              go flames go
                Branding irons
                Hi I have cut out some branding Irons out of 3/8 and 1/4 plate just for fun I have used to brand my gloves boots wallet a few western type picture frames but its only for fun and they dont get used as often as a cattle branding Iron but you can cut very intricate parts
                like mine which is the out line of the state of TEXAS with my little boys initials inside of it or jus my initials hope it helps
                  Freeze brands don't necessarily leave a permanent impression inside the hide; also, they don't leave evidence of subsequent modifying or tampering with existing brands, that can easily be seen with normal hot brands.
                  Biggest mistake I see people make with branding irons, is using too heavy, and too close, iron. Tends to blot and blur. Take a field trip, talk to guys, look at brands, look at irons. If possible,,, watch it being done. It's more of an art than a science, building the things,,, and if you can't stomach the actual application, you probably shouldn't be involved anyway.
                    roughstock
                    dam i wish they freeze branded bulls and broncs it would be a lot easier to see
                    serious welder lol!!!!
                    hobart 140 handler
                    dewalt mitor saw
                    makita grinder
                    dewalt saw
                    dewalt drill gun
                    a nice hammer
                    and some clamps
                      Branding Irons
                      A job I was working on a few years ago, I had a problem with someone walking off with my welding gloves. I made up a branding iron with my initials and i would brand the inside of the cuff of my gloves. That ended the glove disapearance problem
