Originally posted by NorthernLights
Looking for new projects
I made two of Rocky D's welding fingers. One out of 3/8" round bar and one out of 1/2" stock. I did not put a weight on them, but I think they work fine anyway. I also made a plasma cutting grate based upon his design with the removable cutting fins. It works great, highly recommended if you have a plasma cutter.
Here's my version of a welding finger clamp thingy. I use about 20 of them on one welding jig to hold the little parts. They are simple and cheap to make from a small od sq tube. I used 3/8" sq. They slide up between two rails and have spring pressure downward. Sure beats buying 20 pairs of Vise grips...BobAttached FilesBob Wright
Originally posted by RavenI made two of Rocky D's welding fingers. One out of 3/8" round bar and one out of 1/2" stock. I did not put a weight on them, but I think they work fine anyway. I also made a plasma cutting grate based upon his design with the removable cutting fins. It works great, highly recommended if you have a plasma cutter.I'm glad you guys are having fun building these tools.
Originally posted by Stick rodSome really great projects here. Rocky D I noticed your`e Hobart is autographed,who are those that helped with the decorations?
My first projects
I started out very simple, and I can send you plans for each project - my first project was to use rebar to build a C25 cylinder holder for transport, I didn’t like wedging it in between boxes to keep it from rolling around in the back of my truck.
Project #2 was a small welding table that I could clamp onto my Black and Decker workmate.
Projects 3 & 4 were to build new fireplace grates – once again rebar.
Project 5 – Wood storage rack – galvanized fence posts – good for a cord.
Project 6 – was why I bought the welder – fix the rear bumper where my RV storage compartment was attached. Massive stress cracks, and the compartment was almost dragging on the ground.
Project 7 – a collapsible battery holder for my RV that mounts on the front bumper when dry camping to give overnight electricity – and stores in above storage compartment for travel.
Project 8 – Bought a TIG welder that didn’t come with a cart – designed and built the cart.
Project 9 – Modify gas cylinder transport for two cylinders, one C25 the other Argon.
Project 10 – Is in the design phase – a custom fence enclosure for my pool pump station.
Projects 1 through 7 were MIG projects, 8 through 10 are MIG/TIG.
SJM
Originally posted by outlawdanny , ya got any plans for that bender??? looks like that would be a handy tool,,, outlaw,,,
Bottle Rack, welding fingers, welding cart
Here are pic's of a couple of my projects. The bottle rack can either lay down in my truck or be mounted to the front of the bed with the brackets shown on either side. The brackets slide between the bed and the cab and bolt to the frame using the eye bolts at the bottom of the pic. I modified Rocky D's welding fingers by adding a piece of 3/4" 90 degree angle, I stack weight as needed on the angle. My final two pic's are the welding cart I built for my Dynasty 200DX.
