re porosity
I would say the air flow from your fans or even too much pressure from your gun will cause turbulance coming straight from your nozzle(the turbulance tends to draw in contaminants from the air or an unkept or dusty work area)the only other thing i would have to ask (is your gun solely used for aluminum?I know a friend that changes up metals but neglects to remove the liner,which can also carry contamination.If i were you i wouldnt weld anything until i got your settings dead on perfect because it doesnt matter if you have one or a million pieces to do ,take your time and do them all like it was the only one with your signature on it in aluminum good luck
