I am looking for a drive roll replacement part for a Airco Mighty IV Wire Feeder. The top drive roll is pretty worn out and is causing the wire to slip in the middle of when I'm welding.
where to find replacement parts for airco wire feeder?
Tags: None
Arc Products
1245 30th Street
San Diego, CA 92154
800-770-0063
http://www.arc-products.com/
This is where we get all our older Airco parts from. If you can't buy direct they may be able to give you someone in your area that can help you.
Another common problem with those feeders is the clapper assembly, particularly the spring steel tension strip.Last edited by jwsrep; 08-27-2007, 09:34 PM.Rich Ferguson
Sales Technician
Jackson Welding Supply Co.
"Keep America Strong.....Weld It"
www.jacksonweldingsupply.com
