miller 35
  • fun4now
    Tip's are really about the only thing i consider as a consumable for the MIG gun so i just checked them. my bad i could look at other parts if needed. i have had my MIG over 6 years and only replaced tips, so thats what i looked at. should have looked at a few other pieces i suspect to give a fuller answer.
    thanks for the help in pointing that change out.
  • stronics
    fun4now,
    You are correct, the tips are the same. Everything else is different, nozzles and tip adaptors. I just bought a like new MM200 that the nozzle had been damaged somehow and went to the USA Weld HTP looking for nozzles. As stated they have dropped that line.
    With my welder I got several extra tips. Half of them were about 3/8" longer than the standard tips for more stickout I guess. Interesting.
    David
  • fun4now
    do you have the part #'s ?? my book said it was the same tip's ?? strange?? it is an older book but i would think some thing like that would not change??? thanks for the heads up.
  • stronics
    The GA-20C gun is different than the M-25, the nozzles screw on. I just went through this with my MM200. USA Weld doesn't have anything for the GA-20C, they show it on their website but I called and they said that they just haven't removed it yet.
    I emailed Miller and they said that they have everything in stock and to order from a dealer.
    David
  • fun4now
    welcome to the board
    the MM 35 uses a GA-20C gun,( if its original equipment) its tips are the same as the M-25 gun. so you could get tips anywhere they sell the miller tips just ask for tips for a M-25 gun if they don't know what tips you need.
    just about any place that sells tips should be able to sell them to ya.
  • aametalmaster
    http://www.usaweld.com has anything you need for your gun....Bob
  • 1950bombita
    started a topic miller 35
    miller 35
    anyone have luck finding miller 35 consumables on the web ?
