Forks for Tractor Front Loader
  • Forks for Tractor Front Loader
    A friend of mine has a small 28 horse tractor with a front loader. He would like some forks so he can move small palletts and other stuff.
    I thought I would ask and see if anyone has any ideas/recommendations wrt design and type of metal? I seen a home brew set with 1 1/4 solid bar stock with welded brackets that slip on the loader. I also seen flat stock that affix to the loader with bolts, reenforced on the bottom for strength. Recommendations appreciated. Thanks
    Geezer
    Miller 175
    Power MIG 255c
    Ranger 8
    1974 Wisconsin 5K AC Only (Cherry)
    Spool Gun
    185 TIG
    Victor/Harris O/A
    Originally posted by reggie
    channel...slop ends ,box bottoms,size of channel will be dictated by size of tractor and loads...lot of fork extentions made from channels
    Thanks Reggie. Loads about 1/4 ton or a little larger. I think I may have a source for scrap channel 5 or 6 inches wide with maybe an inch or two flange. Flat plat on the bottom should do it.
    What about connecting to bucket? I was thinking about making brackets, welding them to the bucket and fab round rod to the forks for attaching. That way they would adjust easy. I guess we could drill and bolt to the bucket, but then they are only in one position. Make sense?
    Geezer
    Miller 175
    Power MIG 255c
    Ranger 8
    Spool Gun
    185 TIG
    Victor/Harris O/A
      Northern Tool has them in their catalog. You could copy or modify from their pictures.
      Griff
        I made forks for my machine out of 2" square stock wth a 3/16" wall. It is what I had on hand for material and made them 2 tubes wide. I've moved 1500# pallets of stone with them. The clamp uses a stainless steel bolt and nut so it never rusts up. It was all scrap I had on hand. For your machine channel will be best - Solid bar would be adding lots of weight against the total lift capacity of the tractor for little gain.
        One more thing - when you weld them up you are going to be going for lots of penetration - which will cause warpage. For my forks I welded both up in the same manner and they warped the same - so they are even. (some people are probably scoffing at this - but hey - they are scrap metal forks - not a surgical instrument)
        Miller Econotig
        Hypertherm 380 Plasma
        Hobart LX235 AC/DC Stick
        Lenco Spot
        Dan-Mig 5000
        O/A Smith rig
          end of fork towards bucket come up on a 90,top have sleeve of pipe width of channel on top,sides of bucket outside have pockets horizontal to recieve insert that has pipe with 90 hss on each end, pipe long enough to span bucket width.have this set up at height that bottom heal of fork will rest against bucket bottom[cutting edge].pockets can be hss that can be sleeved into another hss that is on pipe ends much like reciever,put a vertical pin between two,pipe on top of fork will sleeve other pipe alowing adjustment and the physics of heal on bucket bottom will keep forks level ,might want to gusset where channels come up on 90...could also drill sleeved pipes for pins to keep forks at desired width
          Thanks Reggie. I think I got it. Appears are suggesting to fab pockets on each inside wall of the bucket to hold one single length of pipe that will rest in the pockets and span the horizontal width of the bucket. Correct? This same horizontal span will fit into the sleeves welded to the top of the forks. Understand the gusset. Am I on target with your recommendation? If not, if you have a pic that would help a bunch. Thanks
          Geezer
          Miller 175
          Power MIG 255c
          Ranger 8
          Spool Gun
          185 TIG
          Victor/Harris O/A
            Griff
            I check it out Griff, thanks
            Geezer
            Miller 175
            Power MIG 255c
            Ranger 8
            Spool Gun
            185 TIG
            Victor/Harris O/A
              GDA, thanks for the pics, those are stout forks!!!! Probably more than we need, but they could be modified to a smaller scale. Stainless steel threaded rod???? Wish I had that stuff laying loose. I'll chew on these suggestions and see where it leads. Thanks for the reply.
              Geezer
              Miller 175
              Power MIG 255c
              Ranger 8
              Spool Gun
              185 TIG
              Victor/Harris O/A
                Wish I didn't
                I built some extended forks for a local cable t.v. company. They said the max load whould be moving 2000lb cable spools.Well I found out there moving 6000lb pound cable spools,I asked nicely please don't do this something bad is going to happen. They still continuing the practice as I cringe.
                  You got it...but I was thinking pockets[recievers] ion outside of bucket walls[sides] to reduce damage to them, depending on what your bucket's use is for.
                  Don't mean to sound like a nag, but I missed something in the translation.
                  How can the horizontal pipe slip through the fork sleeves if the receivers are on the outside walls???? Unless the receivers are mounted vertical on the bucket and the horizontal pipe is formed on each end to a 90 to slip into the receivers. If that is the case, then the forks are always mounted on the horizontal pipe and placed on the bucket as one unit. That may be too cumbersome for my aging friend.
                  I like the flexibility to easily adjust the width of the forks, ofcourse gda purposal is adjustable. I guess the penny has not dropped yet. I just need to get the right mental picture.
                  Geezer
                  Miller 175
                  Power MIG 255c
                  Ranger 8
                  Spool Gun
                  185 TIG
                  Victor/Harris O/A
                    I should not have that problem, his tractor is probably limited to 1/4 ton lift.
                    Geezer
                    Miller 175
                    Power MIG 255c
                    Ranger 8
                    Spool Gun
                    185 TIG
                    Victor/Harris O/A
                      may i suggest you google the tractor model and copy the OEM style for your forks.
                      keep on mind that putting the forks on to the bucket will ad to the leverage point decreasing your lifting capacity.
                      TB 325
                      TB 302
                      dynasty 200sd
                      spoolmatic 30a/wc24
                      suitcase x-treme 12vs
                      miller 211
                      evolution rage 2
                        Good point, done that this PM, appears Massey uses all after markets. Some similar to griff01 and gda suggestions. appreciate the inputs.
                        Geezer
                        Miller 175
                        Power MIG 255c
                        Ranger 8
                        Spool Gun
                        185 TIG
                        Victor/Harris O/A
                          if it was me I would just look for a set of used ones at a scrap yard
                            M.K.
                            Good point, logical, common sense. However, it takes all the fun out of the fab/welding
                            Geezer
                            Miller 175
                            Power MIG 255c
                            Ranger 8
                            Spool Gun
                            185 TIG
                            Victor/Harris O/A
                              I might have posted these before, but here goes. Made from 2 in. channel and 1 1/2 angle. Channel on top angle on the bottom. 2- 3/8 bolts per side bolted from the bottom of the bucket. Hope it helps . I have a TC33 NH
