here are a few pics of the tube inserts I was having trouble with the threads gauding.....I used the anti splatter spray on em' & it worked like a champ!
O! tig welds were done with my Maxstar 200 STR 1/16" root let it fully cool & then a 1/8" cap. As you can see some of the welds aren't capped yet----ran out of Argon
great looking welds. what are you making ? do we get a full pic of the complete toy ??
don't ya hate it when you run out of argon in the middle of something.
i got a backup 80 tank to help keep that from happening. when my big tank is getting close to empty i pull it off and use the 80. this way if the 80 runs out be for i go for a refill there is still a little left in the big one.
although probably not enough to do all the caps.
thanks for the help
sigpic feel free to shoot me an e-mail direct i have time to chat.james@newyorkmetalart.com summer is here, plant a tree. if you don't have space or time to plant one sponsor some one else to plant one for you. a tree is an investment in our planet, help it out.
anytime i do a weld like that i use "never seize" or some call it "anti seize"......nice work i have a 1972 scout i'm going to do a spring over axle conversion....
I had the same problem when I did some on my tie rod and steering link. Ran a tap through them when I was done welding.
Miller Syncrowave 200
Homemade Water Cooler
130XP MIG
Spectrum 375
60 year old Logan Lathe
Select Machine and Tool Mill
I left the rod end threaded into the tube insert with some anti-splatter spray on it, welded the root then let it fully cool then welded the cap and it threads in and out like BUTTER!!!!!! No sticking at all!!!!!!
Lincoln SP170T
ESAB 875 Plasma
Smith oxy set Dynasty 200DX
pulsed mig is next...
