Hello to all from Northern California!
I'm new to this forum although I'm a long-time hobby welder, machinist and motorcycle fancier.
I am the proud owner of one-year old Miller Synchrowave 200 as of this morning. I thought I would come over here so I can learn more about it. It is in perfect condition with little use. At present it has a #17 aircooled torch which I will change to a Weldcraft water-cooled torch that I already have on the shelf.
I traded in a 250/250 TIG Stick Lincoln that had a home-made stainless steel 15 gallon tank with a nice vane pump on top to circulate the water. There is no radiator, just a tank and pump. I kept this when I traded machines thinking that I might use it. The Lincoln was a 1984 Model and the tank was on it when I got it in 1994. The tank and pump sat on a rack and I usually ran it about half full of water with a couple of gallons of GM Dex-cool in it.
In all of the literally hundreds of hours I used the Lincoln on TIG with this cooler, the torch never overheated and I doubt if the water ever even went up three degrees.
The pump has a vintage 1/4 hp motor with a vane rotor inside (one moving part) and it has a very nice stream and pressure although I don't know the numbers. The return stream that empties into a stainless filter cup on top of the tank looks about like a water fountain and has never clogged. The Lincoln was set up so that the water pump would start when the foot pedal was depressed. This also started the gas flow and opened a water solenoid at the same time as the pump started. When you were finished welding, the water pump would run until the post-flow of gas was done.
The dealer that sold me the machine said that he prefers to see the pump running whenever the machine is turned on. The Synchrowave 200 has no water solenoid and he mentioned that a water solenoid really isn't necessary so long as the pump operation is tied to the machine, for example, power could come from one of the two 120 VAC sockets on the front panel of the 200, except I would need to shut it off when doing stick welding....maybe with a separate switch on the pump?
I'm not adverse to getting something like a Miller or a Bernard unit if necessary but this tank has served me well on the other machine and it's extremely well made. I'm going back to the dealer on Monday for the water-cooled fittings for my Weldcraft torch to use on the 200 and then I'll get the machine running.
So.......my question is this; is there any reason why I should be running with a radiator if it seems that the water never heats up with just water/coolant in the tank. ?
Thanks for listening. I'll be shorter next time. Thanks in advance for any comments.
SM
SM
