Hi,
I haven't welded in a while so I am a bit rusty... over 20 years lol
I am using 6013 rods I have 1/8 and 3/32.
I just picked up this Maxstar 140. What amp should I go with around 120- 130?
Should I bevel the new receiver on both sides as i had to cut the old one clean off and how wide a bevel to use?
How wide should I go with the bead if not? I think the metal is 1/4 of hand?
The guy who built it weaved it as you could see from the bottom and then made 3 passes on top.
Should I weave or just make 3 passes as i am rusty.
I believe the duty cycle is 10 mins. How long should I let it rest.
6013 is a contact rod as I remember, correct?
Like I said , its been a while
be good
be good
