I seem to get a slight cover of white dust on my fillet welds when tig welding at high amperatures, does any one know the reasons/effects of this. I have tried all the obvious fixes(gas lens, changing work angles, more, less gas, ect.) to no avail. It's the same dusting that occurs normally on the outskirts of a normal weld, it just covers the weld it self. Any help is appreciated.
white dusting on aluminum tig welds
Tags: None
Originally posted by Clavacle View PostI seem to get a slight cover of white dust on my fillet welds when tig welding at high amperatures, does any one know the reasons/effects of this. I have tried all the obvious fixes(gas lens, changing work angles, more, less gas, ect.) to no avail. It's the same dusting that occurs normally on the outskirts of a normal weld, it just covers the weld it self. Any help is appreciated.
Base Material?
Filler?
Machine?
Joint type?"Better Metalworking Through Research"
Miller Dynasty 300DX
Miller Dynasty 200DX
Miller Spectrum 375 extreme
Miller Millermatic Passport
Miller Spot Welder
Motor-Guard stud welder
Base Material-6061 aluminum tube 2 x 2 x 3/16
Filler-5356 1/16th or 1/8th aluminum rod
Machine-Syncrowave 250
Joint type-fillet weldWelders do it hotter!!
www.Munsonworks.com
I was using the 5356 wire because that is what the company was using befor I got there. After reading your post I was talking with my boss and we deceided to get a bunch of 4043 for me to mess around with. I am using 100% argon for shielding gas.Welders do it hotter!!
www.Munsonworks.com
It sounds to me like you might be overheating the aluminum or the balance control is biased to the penetration side. What # is your balance control set to?
Can you get any pics of the weld(s) for us to look at?
- PaulThe only stupid question is the one that never got asked.
Pre-Anodized or Heat-Treated 6061?
Is the 6061 already anodized? Does in come with any type of protective coating that you might not be getting completely stripped prior to welding it? Is your base material 6061-T6? If it's already been heat treated that may have something to do with it. Let's see what SundownIII has to say about it...he deals with more of the 6061 than I do.sigpic
Clint Baxley
Baxley Welding Service
Rembert, SC 29128
Clavacle,
As mentioned a photo would help us help you.
How easily is the "dust" removed? Does it wipe clean with acetone/rag or does it have to be brushed with SS brush?
Amp setting, balance setting, tungsten size/type, cup size would all help. Also, how much stickout are you using with your electrode. I generally use one or two cup sizes smaller for doing a lot of filet welds
Without the above info, I would guess that the "dust" is coming from the oxides being burned off. Since it is a filet weld, it doesn't dissipate the same as it would with a butt or lap joint.
I'm assuming the base material is not anodized.Syncrowave 250 DX Tigrunner
Miller MM 251 w/Q300 & 30A SG
Hobart HH187
Dialarc 250 AC/DC
Hypertherm PM 600 & 1250
Wilton 7"x12" bandsaw
More grinders than hands
Here are some pics for you guys. My AC balance is set at 8. I am welding with a 1/8 tungsten, with 3/16 stick out. i am using a gas lens with a #6 cup. The base material is 6061-T6 and is not annodized. The whiteness does not come off with a rag of acetone, but a scrub or two from a SS wire brush make it look like it was never there.Welders do it hotter!!
www.Munsonworks.com
Clavacle,
Looks to me like there's still contamination in the bead. Hard to tell if it's coming from the base material or from the tungsten. What type tungsten are you using (old school taught pure for the Sync 250--not anymore)? I would recommend trying 1/8" zirconiated. The second photo, towards the right side, shows something (contamination) on the bead which may have come from the tungsten.
Another factor/question which comes to mind is how was the base metal cut? Was it sheared, saw cut, or cut with plasma. There have been documented cases where the base material, when cut with plasma, introduced a degree of contamination to the weld. Poster (can't remember name) had problems building an aluminum skiff with metal which had been plasma cut. Found he had to grind the edge to remove the contamination.
Balance set to 8 (more penetration) seems a little high, but the etched zone (where cleaning occured) seems more than adequate. I don't think that's your problem.
Don't know what your amp setting was, but I'd try running a little hotter and faster when using 5356 filler.
Also, I'm assuming you did a good job of cleaning the filler material (scotchbrite and acetone wipe). If not, that can also introduce oxides into the weld.
One other thing, I'm assuming you're keeping your filler in the covering gas envelope. Removing it completely and then moving back to the puddle will also introduce oxides.
Keep us posted.Last edited by SundownIII; 08-20-2007, 01:57 PM.Syncrowave 250 DX Tigrunner
Hobart HH187
Dialarc 250 AC/DC
I get that look on a "wash" over
I see where it had the tungsten touched before the present welding.
Miller 30-A Spoolgun
Miller WC-115-A
Miller Spectrum 300
