Bumper metal thickness opinions...
  • vin-man welding
    something like this
    http://www.buckstop.biz/index.html
  • cannon express
    bumper
    Heres mine under way I used 3/16 on main body and 1/2 on supports Still have lots to do.
  • vin-man welding
    you didn't mention the vehicle. if it's a jeep then your looking at 4000lbs lighter then a full size truck. my point is if you going to hammer a rock with 10000lbs or 4000lbs then your going to need thicker steel. I'm going to make some bumpers for my truck and I'm leaning toward just copying some of the ones on the market. there's no way I'd pay $2500 for $200 worth of steel.
  • bretsk2500
    for the vast majority of it, 3/16" would be plenty. only go thicker for your hard points (i.e. shackle mounts and winch plate). If you built all out of 1/2", your bumper would be dragging on the ground from the weight.
  • Scarsman
    started a topic Bumper metal thickness opinions...
    Hi. Sometime in the next few weeks I am going to be starting construction on a front bumper for my truck. I am building it for offroad use, and I want it to be very sturdy and able to withstand impacts against trees, rocks, banks, etc. I will have two bumper shackle mounts, http://www.rokmen.com/products/diy_f...le_mounts.html mounted right over the end of the frame rails. These will pass through the face of the bumper and be welded inside and out and gusseted on the inside to prevent pull through.
    I was thinking of using 1/2" for the front face of the bumper and 3/8" for my top plate. Do you think this is overkill? Should I use 3/8" and 1/4"? I always have a tendancy to over build things.
