i'm trying to learn to stick weld and have gotten OK at flat welds but decided to try welding up wile i had a few sticks left.
i'm still on my first 5 lb box of rod ( i have 40 left so i think i'm about 1/2 way threw it) so don't be too hard on me just give some pointers or some idea of what i should be trying to do?? i really need to see some one do it right before putting too much time into practicing the up part. my flats are not too bad. so a few pointers on how i should be moving the stick or amps changes needed ??
i don't have much material to work with that will work with the rod's i have so i been using some 3/16" diamond plate thats very rusty but i am doing the best i can to clean it up before welding on it. i decided to make a dinner bell out of it so i don't just waist the steel and i been wanting one anyway.
i'm using 1/8" 6013 rod's. a TA-185 (inverter) power source. set at DC 80 amp's. welding on 3/16" steel diamond plate, rusty but i'm cleaning it purity good. they are but welds, not a perfect fit they have some gap's up to about 1/8" max.
the first pic is the only one of the 3 tries welding up i did. the first 2 were so bad i feared breaking the camera so no pic's on them.
yep thats right i have only tried this 3 times, but felt i was so bad i better figure out what i'm supposed to be doing so i don't continue to struggle to get it right when not doing it right to start with. i don't want to keep practicing the wrong way.
i tried doing little circles and a u weave as well as a strait line no weave up weld. none seem to be working out to great. so what should i stick to and try to make work ??
as i'm keeping this thing when i'm done i cleaned up the bad welds and went over them with a flat position weld in a U weave pattern to make it not so hard to look at after i painted it.
any help is greatly appreciated. don't worry about giving beginner pointers as i said i'm still very new at it and have never seen it done right so give me any hints you can think of.
thanks.
pic's
1) is my 3rd rod try at welding up.
2) is the weld grounded off to cover up.
3) is my attempt at a 2nd pass weld to make it look nicer.(done in the flat position)
4) is it painted and ready to make noise. well almost it needs a ring striker still.
thanks.
pic's
