I finshed it and is big
  • I finshed it and is big
    Saaaaweeeeet!!!
    Ed Conley
    MM252
    MM211
    Passport Plus w/Spool Gun
    TA185
    Miller 125c Plasma 120v
    O/A set
    SO 2020 Bender
    You can call me Bacchus
      Bigger pictures, please.
      Miller Maxstar 200 DX
      Miller Syncrowave 180 SD
      Hitachi 4.5" grinder
      http://mhayesdesign.com
        I remember this felling
          Biger is better
            Biger is better
              That thing is beautiful ! I made my own but it's a bit smaller. What do you plan on shaping ?
              Bernard 3500ss water-cooler
              Rockwell vertical mill
              Beverly Shear B-3
              Beverly Shear JR
              Home-made English wheel
              Milwaukee Porta-band
              " Sawz-all
              Tennsmith 36" stomp shear
              Powcon 300st
                Wow!
                That thing is awesome. Great job and thanks for sharing.
                What are you guys working on? I'm in San Diego, too.
                Maxstar 200DX
                Maxstar 300DX
                Passport
                Spectrum 701
                LMSW-52 spot welder
                  D**n, you could wheel a car roof with that!!!
                  How did you make the frame?
                  Be safe
                  Jeff
                  Give more than you get and
                  you will get more than ya need.
                  This is true for the good and bad
                  that life puts out.
                    Some work i did
                      Some work i did
                        Some work i did
                          Some work i did
                            Nice design and work. Post more we can all learn some from you.
                            What is the wheel frame made of... rolled tube steel.... or...?
                              That is one peice "hammer and wheel"
                              THIS ONE WAS THE HARD ONE I MADE TWO SIDES AND WELDED THEM TOGETHER
