possible blade project
  • I Bleed Blue
    Box blade to be or not to be???
    Can anyone tell me if I hace a old snow blabe off a large garden tractor would it make a good rear trailer type box blade for my JD 445? I was planning on building it with wheels and Hydrulics on it to adjust the level of the blade and leave the front of the box open. Anyone see any problem I can't think of befor I put a bunch of man hours in this?? Thanks
  • fun4now
    TSC has them both ways with and without the trailer. about $90 difference between the 2. so i got the one without the trailer and just used my box trailer till i needed another option, then just made one out of scrap.
  • HMW
    I think Northern sells them like that, but I woudl probably do like you did and just make it. Especially if you already have the tank.Nice job
  • fun4now
    its probably way over built but it was all free steel so i just stuck some stuff together.
    if he was near me i would help him out, send him over if he is close.
    now i'm going to work on a kick stand to i can leave it with the hitch up like a boat trailer to just back up to. just have not worked out the way i want to do it yet(been playing stick) but i'll get it there. i need to be able to pull it on and off the mower wile its full so if i need the other wagon on the mower i don't have to lift the water trailer tung and pull it around. lifting is ok as its well balanced but pulling it around is not so easy.
  • jonnymag
    Originally posted by fun4now View Post
    its a 30 gal. tank.
    Thanks, I'll show it to my brother and see what he thinks. Hopefully, he can find someone to build him one
  • fun4now
    jonnymag fun4now,
    Nice water cart. How big is that water tank?
    its a 30 gal. tank.
  • wireburner
    yeah I thought bout putting side pipes on it anda hood scoop
  • fun4now
    jonnymag fun4now,
    i'm not shore the tank size i'll have to check tomorrow. if i had to guess i would say 15-20 ??
    BWS29128 i LOVE that lawnmower!!! i've seen your pictures of it before, and what i REALLY think it needs is some chrome 2-into-4's out of each side of the hood, with a couple spark plugs 2" from the ends, and some new chrome rims with some Blackwater2000 4-wheeler tires in back and some Cragar "skinnys" up front!! Why screw up a good thing with a d*mned blade?!?!?!?!?
    LOL you are not the first to say that. and i have considered side pipes for a wile now, almost added some fake ones just for looks, nice little 4 pack out each side.. i like the extra spark plugs in there though, would look cool at night.
  • jonnymag
    fun4now,
    My brother is a herbicide/insecticide sprayer. Since he started to do some side jobs, he's been looking for a rig to tow his 20-gal tank around the jobsites either by hand or with a mule.
  • BWS29128
    If you were close enough, I'd bring my 54hp John Deere over and move whatever you wanted with the front-end loader and then we'd get down to some serious Bud-time while designing a 4bbl stack and some kewl chromoly headers!!!!!!!!
  • welder_one
    a weighted box blade would actually do fairly well i believe, maybe even a dirt pan on the back just to weight down the back tires and then put a blade on the front. either way about it, you will need to put alot more weight on the drive axle for it to push or pull anything more than a "mower deck". i have seen people take 5 gallon buckets full of concrete or bigger like a 70# grease can full of concrete hang it of the back and push your heart out with a blade. i DO live in arkansas ok, lol
  • fun4now
    if ya got a free blade, then for shore put it on. cant hurt, all it is is a little of your time and you find out if its usefull or not right.
  • wireburner
    Originally posted by HMW View Post
    Actually have messed around with both. [Father owns a lawn/garden equipment business 30+yrs] Tried push blades on sevearl models and the small grader blade with wheel weights and blade weights worked the best. Still no comparison to the Bobcat or the 40hp 4x4 Kubota we have but would move a small amount of loose gravel or dirt. THe old John Deeres and cub cadets were the best. they were the heaviest and you would be surprised how much a 12 hp Kolher would pull, that is if you have enough traction. So in short, nothing beats a tractor/grader/dozer, but for someone to mess around with something and all you have is the riding tractor, go for it.
    And all mower decks come off, the old ones actually had quick attach so they would come off easy so you could use other attachments, Something for a kid to have fun with at any rate
    Yeah it`s to have fun with , it was going to be took to the junk yard and it was FREE
  • fun4now
    Kawasakis are great, parts a little pricey especially if you have to get them from John deer. John deer specs out its engine from kawasaki and they build them for them. Its the same engine as others use but has different part numbers.
    thats what i herd, i was thinking maybe a little looking around could find me a replacement thats just Kawasaki and not Kawasakis J.D . maybe a biyue like my wifes quad would work as a substitute.
    i'll have to take a look after i get it if i get it. if i get my hopes up too high i will end up never seeing it much less getting it.
  • HMW
    Kawasakis are great, parts a little pricey especially if you have to get them from John deer. John deer specs out its engine from kawasaki and they build them for them. Its the same engine as others use but has different part numbers. So in my case the trigger switch is the same but no one has a listing for that engine since it was made for John deer. Since then I've tried the trigger from other Kawasakis on the John Deer kawasaki and it worked fine, just different part number. hope its in good shape
