Just finished it today, taking it in for powdercoat tomorrow. material is 2.5" x 2.5" 11ga and 3/16 and 2" x 3/16" Should support one persone without too much trouble
latest project
latest project
Miller Econotig
Milwaukee Dry saw
Evolution Dry saw (for sale)
Scotchman 350 cold saw
7x12 bandsaw
1910 ATW 14 x 72 lathe
fridge full of adult beverages
Sirius radio
www.snpequipment.com
callouses and burns a plentysigpicTags: None
Mystery ???
Originally posted by STRENGTH AND POWER View PostJust finished it today, taking it in for powdercoat tomorrow. material is 2.5" x 2.5" 11ga and 3/16 and 2" x 3/16" Should support one persone without too much trouble
Originally posted by STRENGTH AND POWER View PostJust finished it today, taking it in for powdercoat tomorrow. material is 2.5" x 2.5" 11ga and 3/16 and 2" x 3/16" Should support one persone without too much troubleLet us know
Miller Maxstar 150 STL
Miller Millermatic Passport Plus
Thermal Dynamics Dragun Plasma Cutter
Protect your seccond ammendment rights! Join the NRA!
Sorry about the vagueness, I had posted a pic of it on a gym forum as well and just assumed everybody would know what it was.
It is called a 45 degree hyperextension. The large flat area is where you feet rest with the round rod on the backside of your leg just above your ankle. The rod will be covered with a 4" dia. foam roll, those haven't made it in yet. he front of your leg rests against the 2 flat plates which will also have a wooden buck with foam and vinyl over them. To use, you bend at the waist and then return back to the starting position using your lower back, hamstrings and glutes(butt muscles). the holes and rods at the front allow for large rubber bands to be looped onto them and over one's neck to provide additional resistance. The main frame will be powdercoated white with the moveable parts and parts that adjust/sleeve over others done in a black texture powdercoat. The vinyl pads will be black and the footplate will get a piece of treadbrite. I will post up the finished pictures once i get it assembledMiller 350P
Miller Econotig
Milwaukee Dry saw
7x12 bandsaw
Sirius radio
finished pics
Looks a lot better finished, Should be a bit more obvious to its use as wellAttached FilesMiller 350P
Miller Econotig
Milwaukee Dry saw
7x12 bandsaw
Sirius radio
ocweld how's things ?
ocweld, Hi;
I just saw your question to me! how are you doing work wise ?
It's SO Slow here I'm almost at a dead stop !!
I sure hope things pick up soon, or I'll go under this Spring !
.............. Norm
