I'm new to the board, (first post), and am impressed with all the knowledge here. As such, how bout some advice?
Last year I purchased a Spectrum 375 with hopes that I could do some artsy type cutouts and for general cutting. I use anything from 24 ga. up to 3/8 steel, aluminum, and copper.
My first cut(s) with it was on 1/4" mild steel. Wasn't too pleased with the results. Rough cut and a lot of slag. I wrote this off to being new to the machine and needing practice. However, this continued for the next several months. Also, my electrodes weren't lasting very long. I replaced them several times during this period. My air supply is triple filtered and is at about 5.5 SCFM at the load.
I discussed this with one of the most personable Miller reps at this year's Sun-N-Fun and he checked my serial number to see if it needed the main pcb replaced. Sure enough, it did. To shorten this story, I had the board replaced by the local warranty repair station and now I have the following experiences.
Again, I'm having rough cuts with a lot of slag. Also this unit is supposed to have the drag tip as standard. When I drag, the tip sticks to the work. Strange. Any ideas? If I can't figure it out, I guess I'll take it to Sun-N-Fun next April and have the Miller guys check it out.
Thanks.
Thanks.
