I removed my neighbors old receiver dish which must have been at least 8-9 ft in diameter. With the exception of the pole mount, and a steel circular backmount..........the dish frame is made of extruded aluminum 1.5x.250 and the screen is expanded aluminum. I cut it up and will keep the material for projects. I have no clue what grade of alum it is. Is there a special rod to tig this or does anyone have recomendations. Nick
What tig rod
What tig rod
Nick
Miller 252 Mig
Miller Cricket XL
Millermatic 150 Mig
Miller Syncrowave 200 Tig
2-O/A outfits
Jet Lathe and Mill
Jet 7x12 horz/vert band saw
DeWalt Multi Cutter metal saw
Century 50 Amp Plasma Cutter
Propane Forge
60" X 60" router/plasma table
and check out some of my ironwork and other stuffTags: None
Monte,
Have no clue as to what grade of aluminum was used to fabricate the dish.
I'd try 4043 filler first to see how it's going to react. Key here is going to be how well you're able to clean up the base metal. I suspect, having been out in the weather for some time, that there is going to be a fair amount of oxidation to deal with.
For the extruded metal, you may want to try a dremel tool with a SS wire brush for getting into those hard to reach places.
Just my .02Syncrowave 250 DX Tigrunner
Miller MM 251 w/Q300 & 30A SG
Hobart HH187
Dialarc 250 AC/DC
Hypertherm PM 600 & 1250
Wilton 7"x12" bandsaw
More grinders than hands
Just my .02Nick
Miller 252 Mig
Miller Cricket XL
Millermatic 150 Mig
2-O/A outfits
Jet Lathe and Mill
Propane Forge
More than likely probably 6063 T5 extruded aluminum. 4043 gets my vote.Rich Ferguson
Sales Technician
Jackson Welding Supply Co.
"Keep America Strong.....Weld It"
www.jacksonweldingsupply.com
Bert,
Sorry to take so long to get back, but wanted to do a little research first. My first response, which was to use 4043, and was seconded by others, was just based on experience (read best guess) based on what has worked for me in the past.
Being an engineer, the more I thought about it, I felt the response needed more substantiation. I have listed two sites which I feel will give you a better explanation of why certain filler materials are chosen. These two sites provide a "basic" understanding. If you wish to delve deeper, you may want to check out the AWS site. (Listed since I'm not up on linking)
http://www.lincolnelectric.com/knowl...nt/tigalum.asp
http://www.lincolnelectric.com/knowl...uminumwire.asp
Bottom line. Sounds like there is substantiation as to why 4043 was recommended.
Anyone else got further references as to the selection of filler material?Syncrowave 250 DX Tigrunner
Hobart HH187
Dialarc 250 AC/DC
SundownIII
Very good reference, thanks.
I noticed they mentioned using 5356 for the spool gun and I have not tried it. Used only 4043 on 6061 and some 3003 plate and it seemed to work well. Would 5356 work any better? Might have to get a spool and try it to see. Also only used 4043 with TIG and repaired lots of alum castings with this filler with good results.Scott
HMW [Heavy Metal welding]
HMW,
You definitely need to pick up a spool of 5356 and try it in the spoolgun. Works great. I tried 5356 first in the HH187 because, for the life of me, I couldn't get 4043 to feed without creating a "habitat for birds".
I probably use 5356 2 to 1 over 4043 in my 30A on the MM251.
As I'm sure you know, you can re-anodize 5356 whereas 4043 will turn black. Just don't want to use 5356 where ambient heat will exceed 165F. (grills would be a prime example).
Let me know what you think.Syncrowave 250 DX Tigrunner
Hobart HH187
Dialarc 250 AC/DC
